front plate.
got my first ticket for no front plate today while parked at work.
where do you guys mount these? i got the bumper plugs so i wanna keep them in and mount it somewhere else. is that illegal in NY?
post of some pics if you have any, im thinking lower driver side.
traffic cops suck.
-Nick.
traffic cops suck.
-Nick.
It's legal as long as it's mounted on the front part of the car (not on the dash, etc). So they ticketed you while you weren't even in your car? While it was parked? That's stupid.
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
Mine turned out pretty good... I took Catawalks idea and kicked it up a notch. He took the OEM plate bracket off and used the bottom hole that's in the center of the black plastic grill insert. He used one of the existing holes in the plate to mount it so it sits off-center. I did the same thing except I drilled a hole in the top center of the front plate so its dead center in the grille
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Originally Posted by angr2387,Jun 9 2009, 04:38 PM
i might do the same dickhead cop gave me a ticket for it also
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
Saw it on my friends GTR. Easily take it off for shows and pictures.
http://blog.stillen.com/2008/11/nissan-gt-...acket-released/
Not sure if I want to pay like 70 bucks for a license plate bracket tho. Might take the stock tow hook and try to do a home depot job with it.
Originally Posted by gofast182,Jun 9 2009, 05:24 PM
Mine turned out pretty good... I took Catawalks idea and kicked it up a notch. He took the OEM plate bracket off and used the bottom hole that's in the center of the black plastic grill insert. He used one of the existing holes in the plate to mount it so it sits off-center. I did the same thing except I drilled a hole in the top center of the front plate so its dead center in the grille ![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
I made some bracket that I custom CNC'ed out of aluminum into a mini L shape. more of a perfect 90 degree V. I drilled two holes on top and used two nuts and bolts to mount it in the center area but back more. The front side of it I drilled two holes to perfectly match my plate. Although it blocks the center, the plate doesn't sit on the front and is recessed to the rear of the center grille opening.
