Atlas Tire changer
Atlas Tire changer (SOLD)
Atlas TC289DAA Dual Assist Arm Wheel Clamp Tire Changer w/Bead Blaster
Tire machine for sale in mint condition. Model: Atlas TC289DAA
Everything works the way it should.
The machine comes with a quick change head but it was converted to a leverless arm which makes bead removal a breeze. The machine comes with:
a) QXLeverless mount demount arm (stock mount/demount plastic and metal duckheads also included)
b) Wheel lift
c) Center Post Adapter with reverse mount adapter for reverse mount wheels
Price is $4,999 OBO with everything included above. I converted this machine to a leverless arm hence the price of the machine. You will not find this specific model being sold with a leverless arm.
**Local pickup only. This thing is heavy and requires a truck and some lifting power**
Atlas TC289DAA Dual Assist Arm Wheel Clamp Tire Changer w/Bead Blaster specs:
Atlas® TC289DAA Specifications
Rims Steel, Aluminum, Alloy
External Clamping Range Position 1) 11 7/8" - 26"
Position 2) 12 7/8" - 27"
Position 3) 13 3/4" - 28"
Internal Clamping Range Position 1) 13 7/8" - 27 7/8"
Position 2) 14 5/8" - 28 7/8"
Position 3) 15 5/8" - 29 7/8"
External Locking Rim Dimension
(With Flip Adapters In The ATV Configuration) Position 1) 5" - 19 1/8"
Position 2) 5 7/8" - 20 1/8"
Position 3) 6 7/8" - 21 1/8"
(With Flip Adapters In The Motorcycle Configuration) Position 1) 15" - 29 1/8"
Position 2) 15 7/8" - 30"
Position 3) 16 7/8" - 31"
Bead Blaster Yes
Maximum tire diameter 40"
Operating voltage 110V 1Ph
Maximum wheel width (Bead Breaker) Position 1) 14 ¾"
Position 2) 18 ½
Air pressure 90 - 110 psi
Maximum Inlet Pressure not to exceed 170 PSI*
Shipping weight 3 Crates: 618 LBS., 154 LBS., & 169 LBS.
Turntable Rotating Torque 885 ft/lbs.
Wheel clamping 4 jaws: internal/external
Bead breaker Pneumatic, 5,500 LB. force
Oiler, filter, regulator Included
Soap reservoir Included
4 Black plastic rim protectors Included
*Inlet pressure is the amount of air pressure that your air compressor is supplying.
Atlas tire changer
QX leverless arm
b) Wheel lift
Bead Blaster Yes
Position 2) 18 ½
Atlas tire changer
QX leverless arm
DAMN!!!
freq (07-17-2019)
Venomous S
08-07-2015 12:45 PM
13darkknight
08-31-2010 10:17 AM
