0-60 3.9 by skipping 2nd Gear!!!!
has anyone seen the new magazing that tested a z06 corvette TT? well i forget what magazine it was in, but since the test car had stock tires on, once the turbos would spool up the tires would be induced into a spin, and once in second gear would spin all the way through, so they skipped 2nd and did still manangaed a 0-60 of 3.9. they did say that you could buy a body kit that would allow for much wider tires in the back but that they were not able to test that version, well if they can get a 0-60 of 3.9 by skipping 2nd i would say that a sub 3sec time might be possible if the get the wider tires. what do you think?
I doubt wider tires alone would help too much.
Probably an improvement of a couple tenths of a second max.
Traction control, a couple of hundred additional horses and removal of all non-essential interior components would do it.
Keep in mind that F1 car does 0-60mph in about 2.5 secs. F1 car weights 1/4 of the Vette, has 1000hp, 7 gears (which change faster than anything on this planet) and tyres wider than anything on a road car. Also, the tyres are made practically out of super-glue.
Point is, nothing on the road can get anywhere close to an F1 car. Even the road McLaren with it's weight of 1100kg and 450kW (600+hp) and every 'best' component/part obtainable does 0-60mph in 'only' about 3.4secs.
I remember a test of a Williams back in the 3.5L days. It did 0 to 100mph (160km/h) and back to zero in just over 4 seconds. I suspect an F1 car can therefore do 0-60 in much less than 2 seconds.
yeah car and driver did a test of the jaguar car and when they only slightly pushed the car they got 0-60 of 3.5, of course jaguar would not allow for an all out test to see its tru limits so you get the idea.
The July Car & Driver has test of two Lingfelter Z06's. One was the above mentioned TT that went from 0 - 60 in 3.9 by skipping 2nd gear and a 427.6 cu in (7007cc) that ran 0 - 60 in 3.4. They were able to put the power down without breaking the tires loose in the non-turbo car. The 427 ran the quarter in 11.7 sec @ 124 mph while the TT ran it in 11.5 sec @ 133 mph.
The TT hit 150 mph in only 14.9 seconds! BTW, both cars were tested on street tires.
