0-60 3.9 by skipping 2nd Gear!!!!
Old Jun 17, 2001 | 01:42 AM
sumir brahmbhatt's Avatar
Default 0-60 3.9 by skipping 2nd Gear!!!!
has anyone seen the new magazing that tested a z06 corvette TT? well i forget what magazine it was in, but since the test car had stock tires on, once the turbos would spool up the tires would be induced into a spin, and once in second gear would spin all the way through, so they skipped 2nd and did still manangaed a 0-60 of 3.9. they did say that you could buy a body kit that would allow for much wider tires in the back but that they were not able to test that version, well if they can get a 0-60 of 3.9 by skipping 2nd i would say that a sub 3sec time might be possible if the get the wider tires. what do you think?
Old Jun 17, 2001 | 02:17 AM
GucciGucci's Avatar
I doubt wider tires alone would help too much.
Probably an improvement of a couple tenths of a second max.
Traction control, a couple of hundred additional horses and removal of all non-essential interior components would do it.
Old Jun 17, 2001 | 07:13 AM
DavidM's Avatar
Keep in mind that F1 car does 0-60mph in about 2.5 secs. F1 car weights 1/4 of the Vette, has 1000hp, 7 gears (which change faster than anything on this planet) and tyres wider than anything on a road car. Also, the tyres are made practically out of super-glue.
Point is, nothing on the road can get anywhere close to an F1 car. Even the road McLaren with it's weight of 1100kg and 450kW (600+hp) and every 'best' component/part obtainable does 0-60mph in 'only' about 3.4secs.
Old Jun 17, 2001 | 07:24 AM
Eze8199's Avatar
I bet with the wider tires, that corvette could get down to atleast the low 3s in the 0-60.
Old Jun 17, 2001 | 09:34 AM
well that vette was a z06TT a c-5 turbo (by ligenfenter sp?) did it in 3.2sec.
Old Jun 17, 2001 | 06:14 PM
naishou's Avatar
Where do you get your information? A modern F1 car has just over 800bhp, not 1000.
I remember a test of a Williams back in the 3.5L days. It did 0 to 100mph (160km/h) and back to zero in just over 4 seconds. I suspect an F1 car can therefore do 0-60 in much less than 2 seconds.
Old Jun 17, 2001 | 06:20 PM
bullit's Avatar
it was car and driver by the way
Old Jun 17, 2001 | 06:22 PM
yeah car and driver did a test of the jaguar car and when they only slightly pushed the car they got 0-60 of 3.5, of course jaguar would not allow for an all out test to see its tru limits so you get the idea.
Old Jun 17, 2001 | 06:52 PM
CG's Avatar
CG
The July Car & Driver has test of two Lingfelter Z06's. One was the above mentioned TT that went from 0 - 60 in 3.9 by skipping 2nd gear and a 427.6 cu in (7007cc) that ran 0 - 60 in 3.4. They were able to put the power down without breaking the tires loose in the non-turbo car. The 427 ran the quarter in 11.7 sec @ 124 mph while the TT ran it in 11.5 sec @ 133 mph. The TT hit 150 mph in only 14.9 seconds! BTW, both cars were tested on street tires.
Old Jun 18, 2001 | 12:11 AM
nvmys2k's Avatar
Good heaven!!!I wish Honda engineers would throw more of those F1 technologies in the STooK.
