10 things that sound dirty but aren't
Old Jun 20, 2008 | 11:40 PM
xxlap1xx's Avatar
LMAO!!
Old Jun 21, 2008 | 08:28 AM
CG's Avatar
CG
Here's some more:
Construction terminology that sounds dirty but isn't,
"I can't finish this dump 'cause there's dirt stuck in my box."
"You'll have to run your packer through the slot a few more times."
"The hoe's in the shop waiting on a new undercarriage."
"Make sure the shaft is clean before you start the pour."
"You better grease the nipple to prevent cracks."
"We need a bigger cat in the pit to clean up the lumps the hoe is spilling."
"Take one more bite from the shaft and I'll see if it's plumb."
"If they need the hoe over there faster, then toss it on the low-boy."
"Wow. Big dyke."
"If the skin friction's too much we'll have to use the vibrator."
"Be sure to check the manhole for leaks before backfilling."
"The sand is pretty abrasive - that's why the box is so smooth."
"It's more secure because of the tongue in groove."
"We got a big rock stuck in the hole - go get the clam."
"It's sort of awkward to lay the pipe when it's bent like that."
"You'll have to use a smaller unit because of the tight access."
"We'll stop pounding once we get 20 blows to the inch."
Old Jun 21, 2008 | 06:37 PM
DC5 RSX R's Avatar
The golf ones are pretty funny
Old Jun 21, 2008 | 07:48 PM
Sabre's Avatar
As Demitri Martin said:
"Have you noticed the phrase 'Finger Puppets" only sounds OK as a noun"
Old Jun 21, 2008 | 07:50 PM
Backspin23's Avatar
Well digger
"Stop! you're going too deep!"
"be gentle with those hoe's...they're new"
"I'm exhausted, that took so long"
"you're drill bit is huge"
"No damit, that's the wrong hole"
just made 'em up me-self.
WarrenW
Jun 5, 2010 02:46 PM
Stradale
Γενικά Θέματα εκτός S2000
Mar 3, 2010 06:02 AM
ruexp67
The Windy City - Off Topic
59
Mar 15, 2006 06:08 AM
Palmateer
Jan 19, 2002 12:27 AM
