Can Anyone Help Me Out With Microsoft Excel
Old Jan 15, 2003 | 11:33 AM
wantone's Avatar
Default Can Anyone Help Me Out With Microsoft Excel
I was wondering if someone can teach me how to insert a formula for an entire column? So when I input a specific number like 55 in that column, it'd come out 57.89. Is this possible? Thanks in advance!
Old Jan 15, 2003 | 11:51 AM
KAMcDonald's Avatar
open worksheet
in cell b1, type in your formula.... ie =a1*1.0525454 for your 55 and 57.89 example...
select/copy field b1 (ctrl-c) select/highlight column by right click column B header, then paste special, formula. all of column b should now be 0.
when you put a value in column A, corresponding B cell value will show your desired result.
keith
Old Jan 15, 2003 | 12:00 PM
wantone's Avatar
KAM, You da man... Thanks a BUNCH! A small token of my appreciation...
Old Jan 15, 2003 | 12:05 PM
iispms's Avatar
Ask some more questions!!!!!
Old Jan 15, 2003 | 02:14 PM
4IGS2000's Avatar
Spammer
ctrl D to dump the same formula or data in 1 particular column
Old Jan 15, 2003 | 02:35 PM
wantone's Avatar
What do you mean dump, B?
Old Jan 15, 2003 | 09:24 PM
wantone's Avatar
[QUOTE]Originally posted by KAMcDonald
[B]open worksheet
Old Jan 15, 2003 | 10:39 PM
SteveUCI's Avatar
[QUOTE]Originally posted by wantone
[B]
OK, now that I have column B results, how do I get rid of Column A?
Old Jan 15, 2003 | 11:43 PM
4IGS2000's Avatar
Spammer
You know when you take off your pants, and they end up around your ankles in a sitting position
actually i meant to say in a non ghetto/slang english term is: paste the formula in a selected column.
What you do to make the same formula constant in 1 particular cell is:
highlight the selected column to as many rows as you desire starting with the original line with the formula then hit CTRL D while the cells are selected
That fills down that formula through the highlighted columns. I dunno if that was what you need
Old Jan 16, 2003 | 04:22 AM
KAMcDonald's Avatar
if you have to get rid of the column A figures....
select all off the data values in column B and copy them (ctrl-C)
move over to column C
select edit, paste special, values, OK.
delete both column A and column B
keith
