Computer gurus: Need help diagnosing win98 problem
Old Feb 13, 2003 | 04:29 PM
dhess's Avatar
Default Computer gurus: Need help diagnosing win98 problem
Hi guys,
I have a win98 PC which freezes up every fifteen minutes or so for about 2 minutes and then unfreezes itself.
What do you think the cause is? It has only started doing this recently and has not had any modification software or hardware done for a long time before the problem.
Could it be a virus?
What could be the solution? Re-install win98?
Thanks,
Dominik
Old Feb 13, 2003 | 05:24 PM
Liebernoodle's Avatar
Question: Is the harddrive light on during these freezes? As in, does it seem to be reading A LOT from the harddrive during the freeze?
Old Feb 13, 2003 | 07:52 PM
dhess's Avatar
Sorry forgot to mention. No hard drive activity during freeze. Pretty weird huh?
Old Feb 13, 2003 | 08:09 PM
MikesS2K's Avatar
has the computer been on for a long period of time?? it can be a heat related issue.
Old Feb 13, 2003 | 08:14 PM
dhess's Avatar
No it happens when it has not been on for very long as well.
Old Feb 14, 2003 | 08:18 AM
Kroeker's Avatar
Hi,
Many different things could cause this problem, try the following to eliminate some of the common causes:
Take off the cover to the computer, inspect your power supply fan, cpu fan and any other fans that are installed. Are they spinning. Leave the system on, during the time that the system hangs, are the fans still running? Did having the cover off, lengthen the time that it takes for the system to hang? You may have a heat related problem if the fans are not working.
Look in your cmos setting or control panel settings for power management. Are your hard drives spinning down after 15 mins? Disable all power management features and see if this helps.
Delete the contents of c:windowstemp and reboot. This will get rid of corrupted temp files.
Download adaware 6.0 from lavasoftusa.com, install and get rid of any spyware software.
Hopefully this helps.
Keith
Old Feb 15, 2003 | 03:12 AM
dhess's Avatar
Thnaks for the suggestions.
Will try.
Old Feb 15, 2003 | 01:49 PM
MikesS2K's Avatar
If it doesn't, just reinstall windows right over it again. If you want to have a clean and more stable system, reformat then reinstall windows.
VTEC_Junkie
Mar 7, 2005 01:27 PM
C45P312
Jan 27, 2005 09:17 AM
Lee355
Jun 8, 2003 02:21 PM
VisualEchos
Oct 15, 2002 10:49 AM
WhataRide
May 5, 2001 08:19 PM
