Couple of questions for you Math guys. Please Help!
Old Jun 10, 2004 | 01:29 PM
jsc2K's Avatar
yeah...I talked to my TA about it, and he told me that I couldn't prove it that way. He said probably no on is going to get it. I am having trouble following your explanation on #2. I kind of get how you get your answer, but I don't know how to prove it with work. Thanks again for your help
Old Jun 10, 2004 | 07:59 PM
CyrusA's Avatar
when is this test due? the question you about proving divergence sounds familiar and i could swear ive done it before. if i have time i will look throgh my old notebooks and see.
Old Jun 10, 2004 | 08:06 PM
jsc2K's Avatar
Due on monday. thanks
Old Jun 10, 2004 | 08:32 PM
magician's Avatar
Originally posted by frycow
The series will converge, because the upper bound of cos n/n from 1 to infinity is 1 and the lower bound is -1.
The upper limit (n->infinity) is 0.
The lower limit (n->1) is 0 as well.
That should get you started.
This won't help. The harmonic series meets all of your criteria and is divergent.
I haven't worked with infinite series for quite a while. I'll have to ponder this one a bit.
To prove that the series is not absolutely convergent, you must prove that the sum of |cos n/n| (absolute value) is divergent.
Hint: A series with a sum that is always greater than or equal to than another, divergent series, is divergent.
Hint: The series 1/n from 1 to inifinity is divergent.......
This won't help, either. Consider a limit comparison test.
Since A^2 = A, you know that A*A = A. Therefore, A^-1 = the identity matrix. Since A has in inverse, A is nonsingular. A = I^-1. Therefore, A = I.
This is wrong. There are idempotent matrices other than identity matrices. Your mistake is in your assumption that A in nonsingular.
As an example:
1 0
0 0
When finding eigenvalues, you want to find lambda such that A*x = lambda*x.
That can be rewritten as (A - lambda * the identity matrix of A)*x = theta, where x does not equal theta.
Skipping ahead, the only possible eigenvalue of A is 1. I'll let you prove it.
This starts out fine, and finishes, well, wrong.
A*x = kx, where k is an eigenvalue of A.
(A*A)*x = A*(A*x) = A*kx = (k*k)x, where k is still an eigenvalue of A.
But, A*A = A, so kx = (k*k)x for all eigenvectors x. Solve this equation; it has solutions other than k = 1.
Old Jun 10, 2004 | 08:39 PM
magician's Avatar
Originally posted by CyrusA
what math is this? i could possibly do a) and b) but i wouldnt know how to set up the diff eq for c
C does not involve differential equations. It's linear algebra.
Old Jun 10, 2004 | 08:42 PM
magician's Avatar
Originally posted by EvoVII
PM magician if you have any other problems, if he's online he'll help, I think he's a math teacher or something
Thanks, Evo!
I teach math at CSUF and may be teaching risk management at UCI this Fall.
Old Jun 10, 2004 | 08:54 PM
CyrusA's Avatar
[QUOTE]Originally posted by magician
Old Jun 10, 2004 | 09:01 PM
magician's Avatar
oh. i havent taken lin alg, just used eigenvalues/vectors in diff eq
Eigenvalues and eigenvectors appear in the theory of systems of linear differential equations. The solutions to homogeneous systems are derived using techniques from linear algebra. What a shame that they didn't make that clear in your diffy-q course.
(I've taught a course in linear algebra and differential equations several times.)
Old Jun 10, 2004 | 09:24 PM
Officer_down's Avatar
Banned
Magician, you sound like you know a thing or two about math.
Old Jun 10, 2004 | 09:46 PM
CyrusA's Avatar
haha yea he does.
[QUOTE][SIZE=1][B]Originally posted by
