Dead Pixeled Monitor
Old Aug 17, 2003 | 09:29 AM
MrForgetable's Avatar
Default Dead Pixeled Monitor
So, this morning, I turned on the computer, everything was fine, went on S2ki, fine, then all of a sudden, I noticed this faint blue line as I was posting, which was straight, so I was like, Whoa, so I closed the browser, And there was this blue line that extends vertically down the monitor except for an inch at the top. So I freaked out and restarted the compouter, and the blue line was there every step of the way. When I restarted, the start up, everything, except the moment I turn on Internet Explorer, it stops for a few milliseconds, then goes back to the blue line. I'm guessing these are dead pixels, and I just wanted to make sure. It won't go away! I have a KDS VS 15 inch Flat screen if that helps any. Thanks
George
Old Aug 17, 2003 | 09:34 AM
sebrings2k's Avatar
dead pixels tend to be white not blue.
it could be your connection ports or a faulty video card.
try re-installing your driver, re-connect your ports and if you still have a problem....it's time to get a better LCD!
Old Aug 17, 2003 | 12:46 PM
iatacs19's Avatar
you have an LCD or CRT? Dead pixels are very rare in CRT's although they are common in LCD's.
Old Aug 17, 2003 | 12:48 PM
I lost you after "re-installing your driver" I have an 32 MB nVidia GeForce2 MX card, What does reconnecting the ports mean? Pulling the Monitor->Computer plug?
YES I KNOW I SHOULD GET (should've gotten) A BETTER LCD But I'm not since I'm saving up for another Mac
Old Aug 17, 2003 | 02:03 PM
rworne's Avatar
If it a single line of pixels, then the connector to the LCD is bad. LCD panels work as a matrix, and whole banks of pixels can go dead -- think of the problems with the original yellow-screened GameBoy.
Nothing much you can do with it. You can verify the hardware problem by simply swapping with a known good monitor. Or tap around the edges of the screen (not on the screen) and see if the line flickers on and off.
A severe example of this problem is shown on the top image of a laptop on this page:
http://www.laptopking.com/symptoms.htm
Old Aug 17, 2003 | 02:30 PM
The Line does not Flicker when I tap around the edges. But it does disappear when I go to "My Computer". That's what's weird Most of the time it's there, but sometimes it's not. And yes, it is one single, vertical line about 3/4s of the way to the right.
Old Aug 17, 2003 | 02:52 PM
rworne's Avatar
[QUOTE]Originally posted by MrForgetable
[B]The Line does not Flicker when I tap around the edges.
Old Aug 17, 2003 | 02:56 PM
It's too much to the right that the Menu can't get a chance to overlap, but when the computer was off, and I turned the monitor on, the line was still there.
Old Aug 17, 2003 | 03:51 PM
DaveZ's Avatar
Is it a single-pixel width wide? If so, I had the same thing happen on an IBM monitor. Sent it back for replacement.
Old Aug 17, 2003 | 04:51 PM
Yeah, it's 1 pixel wide. I've had this Monitor for 3-4 years now...
