Hey Magician, math problem for ya!
Old Oct 31, 2003 | 12:43 PM
TrojanHorse's Avatar
Default Hey Magician, math problem for ya!
Go here..
http://digicc.com/fido/
I know this is just a sequence of math manipulations to get the answer but what are they?
Old Oct 31, 2003 | 02:00 PM
ZGiRL's Avatar
Well, the way I can figure it out is because when you take a number and subtract out a mixture of itself, the result of the numbers will add up to 9.
For example, take 9721 and subtract out 7912 = 1809 = 1+8+0+9 = 18
9721-1279 = 8442 = 8+4+4+2 = 18
9721-2179 = 7542 = 7+5+4+2 = 18 etc.
So if you put in 109 for 1809, it will guess 8 because 9-1=8 and 9-9=0 and so on. That's the best I can explain it. Hopefully a real mathematician can make it more clear.
Old Oct 31, 2003 | 06:40 PM
magician's Avatar
ZGiRL has the essential points:
1. When you have two numbers with the same digits and subtract one from the other, the difference is always divisible by nine.
2. When you add the digits of a number divisible by nine, the sum is divisible by nine.
All the website is doing is adding up the digits you type in; if the answer is a two-digit number, they add those digits till they get a single digit number. Because all of the digits must add to nine, subtracting this final sum from nine gives the missing digit.
Note that if the final sum is a nine, the missing digit is a nine, because the rules say you may not circle a zero.
(If you want to see why the first two statements are true, let me know; but be prepared for some number theory that may be difficult to follow.)
aznkid310
Oct 16, 2006 06:15 PM
north9586
Apr 7, 2005 12:49 AM
JasonX82
Nov 9, 2004 04:43 PM
The Raptor
Jan 15, 2002 05:03 AM
