How do I format my computer??
Old Apr 7, 2003 | 04:13 PM
EvoVII's Avatar
Default How do I format my computer??
I lost the re-instillation/ windows back-up CD (whatever it's called) that came with my Dell. Can I still format my computer through dos or something?? I'm computer competent, but not computer literate
Old Apr 7, 2003 | 04:28 PM
WhiteS2k's Avatar
If you format your hard disk, you'll need to install something (Windows, Linux, Lindows, Solaris, BE-OS, OS/2, DOS, ...) on it before you can use the computer again. So if you don't have the Windows installation CD, you should go and beg/borrow/buy a copy before you reformat your hard disk.
Old Apr 7, 2003 | 06:17 PM
4IGS2000's Avatar
Spammer
yeah go to dos
c: format c:
or was it
c: format c
i forgot dos crap
make sure you Fdisk that bad boy too
Old Apr 7, 2003 | 08:34 PM
RazorV3's Avatar
[QUOTE]Originally posted by 4IGS2000
[B]yeah go to dos
c: format c:
or was it
Old Apr 7, 2003 | 09:32 PM
MyEeek's Avatar
Get a windows boot disk (you can usually make a start up disk through windows), boot with CD-ROM support. When you get to the dos prompt ( c: ) type:
format c:
Just follow what it says (usually just a warning about all data being lost) and when your done, goto your cd-rom drive (usually assigned to the letter "d:" but it could also be e:) by typing: d:. Then type setup. Folllow instructions from there, good luck!
Old Apr 7, 2003 | 09:34 PM
sebrings2k's Avatar
what platform are you on?
if you have WinXP you can re-set your C: insted of formatting.
good luck.
-SS2K
Old Apr 7, 2003 | 11:55 PM
AquilaEagle's Avatar
Administrator
he's gone - he's done the format and now cant get back I bet
Old Apr 8, 2003 | 05:04 PM
ViROID's Avatar
The command would be...
FORMAT C:
FORMAT C: /S
if you would like the the system files copied over. But as stated above, it really helps to have something to put back ON the computer before doing this.. =)
FDISK will allow you to create/delete partitions on the drive, FDISK /MBR will clear your Master Boot Record. (IE, those damn errors you get if you don't completely install DOS 5)
ViROID
eridia78
Jun 23, 2004 02:56 PM
whytei3oi
Aug 27, 2003 11:48 AM
Lee355
Jun 8, 2003 02:21 PM
come_undone
Nov 19, 2002 08:44 PM
