Impossible Objects. Intersting stuff
Old Jun 9, 2004 | 04:07 PM
  #21
WhiteS2k's Avatar
Originally posted by Tedow
This is correct. Water is the exception to the rule. I'm not sure that liquid nitrogen would get the sphere to shrink enough to get in there, but it's tough to tell from just the photo. That might work. My only other thought would be for a hunk of wood to be grown around the sphere, then cut to make the box. Not sure if that's possible either.
Sorry to go off in a tangent, but this discussion reminded me of a question that has always puzzled me: If you have a sheet of metal with a hole in it (a ring would not work in this example because it is too thin), what happens to the hole when the metal is heated? Would the hole get bigger, smaller, or stay the same size? A ring would expand, so the hole gets bigger. But when you have a large piece of metal around the hole, will the expanding metal cause the hole to become smaller?
Old Jun 9, 2004 | 07:26 PM
  #22
Austblue's Avatar
If the metal was to expand then you'd get tensile strain in that region and if it were to contract then you'd get compression buckling probably.
I only thought about water when considering the heat = expand, cool = shrink because the first thing that popped into my head was that when water in a crack freezes it expands and spreads the crack further. I had a feeling that there was more to it thanks for the clarification.
Old Jun 9, 2004 | 07:29 PM
  #23
Purple_sky's Avatar
All those are so time-consuming.
C U AT 9K
Dec 8, 2009 06:13 AM
wantone
Dec 27, 2005 04:43 PM
emrillive
Jun 22, 2005 12:26 PM
