View Poll Results: Should the contestant stick with his door, or switch?
Definitely stick with his original door
13.73%
Stick with his original door, but it's close
0%
It doesn't matter; it's 50-50 either way
54.90%
Switch to the other door, but it's close
1.96%
Definitely switch to the other door
29.41%
Voters: 51. You may not vote on this poll
Interesting logic problem
Old Oct 18, 2005 | 10:00 AM
  #41
WestSideBilly's Avatar
But he doesn't pick first. Monte's choice depends on yours.
Old Oct 18, 2005 | 10:02 AM
  #42
Ubetit's Avatar
Go play this applet and let us know the results.
http://www.stat.sc.edu/%7Ewest/javah...MakeaDeal.html
I played 50 times. Look at the odds.
Switched choices 25 times - 18 winners
Didn't switch 25 times - 8 winners
Old Oct 18, 2005 | 10:07 AM
  #43
SIIK2NR's Avatar
That was in reference to CHANGE THE SHOW....
Back to the REAL show... Yes, Monte's choice is dependant on the contestant, but the CONTESTANT does not know if Monte is forced or randomizing his decision. That is why the contestant can pick any door they want FIRST. It doesn't matter because the end result to the CONSTESTANT is 50/50. AND is the same as if Monte DID infact choose first....he STILL cannot choose the one with the car.
Monte's decision is NOT based on the contestants decision.....that is why he can pick FIRST or SECOND.....DOESN'T MATTER.
Monte's decision is based on which door the car is behind. Because there are 3 doors to start....the end result again is 50/50.
Old Oct 18, 2005 | 10:08 AM
  #44
magician's Avatar
Originally Posted by SIIK2NR,Oct 18 2005, 09:48 AM
Once you stopped using the fair six sided dice to choose for Monte....it's no longer relevant...
I don't understand this comment.
When Monty has a choice, it's decided randomly and fairly (using the die).
When Monty doesn't have a choice, he shows the only door he can.
[QUOTE=SIIK2NR,Oct 18 2005, 09:48 AM]Monte picks the door he HAS TO.... but to the contestant it is just like Monte rolled the dice to pick it.
Old Oct 18, 2005 | 10:11 AM
  #45
"Despite a very clear explanation of this paradox, most students have a difficulty understanding the problem."
Old Oct 18, 2005 | 10:13 AM
  #46
exceltoexcel's Avatar
Originally Posted by SIIK2NR,Oct 18 2005, 01:04 PM
At first glance this systems seems to work but it is not without flaws.
To Monte the answer is obvious but to the contestent they still have no advantage.
If you pick #2 and it is a goat..... you don't know that yet.
Monte has the option of #1 or #3 and he will pick #3. Although Monte has no choice but to pick #3.....you don't know that. You are still led to believe that he could have picked either #1 or #3.
So in essence you are in the same situation as if you had picked #1 in the first place. You would think you were right and wouldn't change your mind and in fact would have picked a goat.
They system is to the Game show advantage.
The odds after drawing out 1 of 3 balls is not 33% after drawing one of the balls out. The odds of "probability" will be slightly in your favor but the true odds would be 50/50.
It's luck... bottom line.
That's what i thougt. I initially saw it as two exclusive events but it is not. This explains it Damn it I just didn't take enough time to think about it. The answer is always switch.
http://en.wikipedia.org/wiki/Monty_Hall_problem
Old Oct 18, 2005 | 10:15 AM
  #47
If you made it a two door game, then yes, it is 50/50. But it's not.
In the 3 door game (or any amount of doors greater than 2, where all but 2 are opened to reveal goats after the contestent chooses), Monte does not have a choice - the door he opens is dictated by the contentesten's choice. You're right, the contestant doesn't know if Monte randomized or was forced, but statistically the contestant is twice as likely to win by switching. A sample of 1 would appear to be 50/50 (he either won or lost), but the greater the sample size, the clearer it becomes that switchers are more likely to win.
Old Oct 18, 2005 | 10:18 AM
  #48
SIIK2NR's Avatar
Very interesting read....
I totally agree with the probability at the very begining being 2/3 of getting it wrong.....therefore changing your decision at the end would statistically show the advantage.
This goes back to my original statement of 1:3 odds of picking the right one and sticking with it.
Also covered when I gave the example of picking a GOAT instead of a car and then switching at the end.
Bottom line....
I was wrong...
Although the final decision is 50/50.....the laws of probability favor switching due to the initial 2/3 advantage during the first pick.
Old Oct 18, 2005 | 10:32 AM
  #49
SIIK2NR's Avatar
"MY" mistake is when I gave the example of trying to pick a goat instead of a car with the first 3 doors that the solution always ended up to switch at the final decision and I didn't catch that... therefore missing the advantage.
I was set up!!!
Old Oct 18, 2005 | 10:46 AM
  #50
magician's Avatar
I'm not sure what you mean when you say the final decision is 50/50, and I'm not sure that you are sure what you mean.
If you simply mean that there are two choices - one correct, one incorrect - then you are right.
If you mean that one choice is correct 50% of the time and the other is correct 50% of the time - what, I suspect, most people mean when they say "50/50" - then you're wrong.
The final decision is not 50/50; it's 33.333/66.667 (stay/switch).
