Need Computer Help
Old Feb 8, 2005 | 05:32 AM
GodoftheBOLP's Avatar
Default Need Computer Help
Okay, so my main pc wont connect to the internet now, however the wireless is still working fine, I checked all of my connections there all
When I go into my network card it says this:
Problem:
The system has not enabled IO address mapping fo the device you have installed. The device driver will not work correctly on this adapter.
Possible Causes:
PC BIOS is set to Plug and Play
Possible Solution:
Try turning off Plug and Play in the PC BIOS.
okay, so where is pc bios, and are there any other causes? or fixes?
Thanks for the help guys.
Old Feb 8, 2005 | 06:01 AM
Gink5's Avatar
I'm assumeing your main computer is hard wired into the router(as apposed to wireless). Do these steps in order.
1. turn off PC, cable modem and router.
2. Turn on cable modem
3. Turn on Router
4. Turn on PC
If this does not work. Ill need more informatiom. i.e operating system, type of router, what happens when you try and log onto the internet, any other system erros.
Old Feb 8, 2005 | 07:30 AM
Hey, thanks anyways for trying to help, I just pulled a system restore, I needed to clean up the puter anyways
Old Feb 8, 2005 | 07:46 AM
Gink5's Avatar
I know this happens to alot of people. It has to do with dynamic ip changing with out the router and computer syncing. Usually rebooting everything helps. Keep this in mind if it happens in the future.
emrillive
Feb 7, 2003 02:16 PM
redleader
Aug 26, 2002 04:42 PM
