oral conception
Old Feb 3, 2010 | 09:05 PM
rustywave's Avatar
Default oral conception
http://blogs.discovermagazine.com/discoblo...ous-conception/
Oral conception. Impregnation via the proximal gastrointestinal tract in a patient with an aplastic distal vagina. Case report.
[Ed. note: There is no abstract, so we're including most of the original article below. It's a bit long, but trust us--it's worth the read!]
“Case report:
The patient was a 15-year-old girl employed in a local bar. She was admitted to hospital after a knife fight involving her, a former lover and a new boyfriend. Who stabbed whom was not quite clear but all three participants in the small war were admitted with knife injuries.
The girl had some minor lacerations of the left hand and a single stab-wound in the upper abdomen. Under general anaesthesia, laparotomy was performed through an upper midline abdominal incision to reveal two holes in the stomach. These two wounds had resulted from the single stab-wound through the abdominal wall. The two defects were repaired in two layers. The stomach was noted empty at the time of surgery and no gastric contents were seen in the abdomen. Nevertheless, the abdominal cavity was lavaged with normal saline before closure. The condition of the patient improved rapidly following routine postoperative care and she was discharged home after 10 days.
Precisely 278 days later the patient was admitted again to hospital with acute, intermittent abdominal pain. Abdominal examination revealed a term pregnancy with a cephalic fetal presentation. The uterus was contracting regularly and the fetal heart was heard. Inspection of the vulva showed no vagina, only a shallow skin dimple was present below the external urethral meatus and between the labia minora. An emergency lower segment caesarean section was performed under spinal anaesthesia and a live male infant weighing 2800 g was born…
…While closing the abdominal wall, curiosity could not be contained any longer and the patient was interviewed with the help of a sympathetic nursing sister. The whole story did not become completely clear during that day but, with some subsequent inquiries, the whole saga emerged.
The patient was well aware of the fact that she had no vagina and she had started oral experiments after disappointing attempts at conventional intercourse. Just before she was stabbed in the abdomen she had practised fellatio with her new boyfriend and was caught in the act by her former lover. The fight with knives ensued. She had never had a period and there was no trace of lochia after the caesarean section. She had been worried about the increase in her abdominal size but could not believe she was pregnant although it had crossed her mind more often as her girth increased and as people around her suggested that she was pregnant. She did recall several episodes of lower abdominal pain during the previous year. The young mother, her family, and the likely father adapted themselves rapidly to the new situation and some cattle changed hands to prove that there were no hard feelings.
Comments
A plausible explanation for this pregnancy is that spermatozoa gained access to the reproductive organs via the injured gastrointestinal tract. It is known that spermatozoa do not survive long in an environment with a low pH (Jeffcoate1975), but it is also known that saliva has a high pH and that a starved person does not produce acid under normal circumstances (Bernards & Bouman 1976). It is likely that the patient became pregnant with her first or nearly first ovulation otherwise one would expect that inspissated blood in the uterus and salpinges would have made fertilization difficult. The fact that the son resembled the father excludes an even more miraculous conception.”
before you call fake, here's the link to the abstract:
http://www.ncbi.nlm.nih.gov/pubmed/3191066
pretty crazy if true!
Old Feb 3, 2010 | 09:27 PM
CKit's Avatar
Second coming of Christ?
Old Feb 3, 2010 | 09:58 PM
C U AT 9K's Avatar
Yes, oral conception works. But someone needs to stab you.
Old Feb 3, 2010 | 11:16 PM
ahrmike's Avatar
lol well, what doesnt make sense is how does she not have periods but for some reason at that exact time, have a fertile egg in her womb?
I mean, everything else is somewhat believeable - a stretch, sure, but believeable...
Actually, I take that back. There is no way sperm could survive in Hydrochloric acid - sperm isnt that hardy - they need some sort of saline solution to survive. 1 min in HCL would probably kill all the sperm she injested~
The only way was if the boyfriend ejaculated on the knife, which then punctured her womb, assuming the sperm did NOT get wiped off as it entered her - then it somehow ends up traveling around inside of her til it reaches a -for some reason- fertile egg although she had no previous signs of fertility...then yeah, its psosible - (not).
Old Feb 4, 2010 | 06:57 AM
The Gasman's Avatar
I guess anything is possible, but this is HIGHLY unlikely.
Old Feb 4, 2010 | 07:01 AM
GateCrasher's Avatar
^^ I'm with the doctor
If true it must have been under perfect circumstances.
Old Feb 4, 2010 | 08:08 AM
C U AT 9K's Avatar
^ Perfect circumstances AKA getting stabbed in the stomach.
Old Feb 4, 2010 | 08:14 AM
The Gasman's Avatar
More than just that. The likelyhood of sperm making it from the stomach undigested and then through the body cavity and then down to the pelvic organs and then to the egg. It's just too unlikely. I think there must be an alternative explanation.
Old Feb 4, 2010 | 08:20 AM
ou818's Avatar
Was the pregnancy ectopic or did the sperm somehow supposedly make it's way into the uterus on its own?
Old Feb 4, 2010 | 04:47 PM
rustywave's Avatar
can the doctors access that original 1988 article (2nd link)?
