Programming questions
Old Dec 14, 2005 | 11:08 AM
stockae92's Avatar
Default Programming questions
for C# in .NET
in the .cs code behind file, can i highlight (select) items in a ListBox?
i need to select items in a ListBox in the .cs file
is there a property like that?
thanks in advance
Old Dec 15, 2005 | 07:22 AM
Gink5's Avatar
I'm sure i can help if you rephrase the question. It seems you are trying to open the file with the code? or are yuo trying to make a list box and select multiple items at once?
Old Dec 15, 2005 | 07:33 AM
cyber_x's Avatar
i work mostly with win32 api stuff, so dunno much about c#, but in most cases the items in a listbox should be an array. try something like this:
listbox.items[0].selected = true;
could be a bit screwed up, but to do whatever it is you're going for, you almost certainly need to access the items[] array.
Old Dec 15, 2005 | 07:51 AM
Gink5's Avatar
c# looks alot like java
Old Dec 15, 2005 | 07:52 AM
cyber_x's Avatar
ok looks like i did have a c# tool on my system after all. you can do it by the item name like so:
listBox.SelectedItem = "your item";
or you can do it by the item's position in the array, collection, or whatever it's called in c#:
listBox.SelectedIndex = 2;
Old Dec 15, 2005 | 07:58 AM
Gink5's Avatar
[QUOTE=cyber_x,Dec 15 2005, 08:52 AM] ok looks like i did have a c# tool on my system after all.
Old Dec 15, 2005 | 08:05 AM
cyber_x's Avatar
i figured he's using winforms (because of the ".cs code behind file" part) and just wants to write the code to highlight a listbox item
sent ya a pm regarding your question
Old Dec 15, 2005 | 08:27 AM
stockae92's Avatar
ops, i found a way
to select all listbox items:
foreach(ListItem i in ListBox.Items)
i.Selected = true;
and i assume i can do something like this:
ListBox[i].Selected = true
to select a certain item(s) in the ListBox
Anuj
NYC Metro Off Topic
Mar 16, 2010 10:57 AM
s2kdriver80
May 30, 2003 03:36 PM
mingster
Apr 11, 2001 09:26 PM
