question for the geeks regarding burning CD's...
Old Dec 21, 2002 | 06:39 PM
Schatten's Avatar
Default question for the geeks regarding burning CD's...
Using Nero, I came across a VCD I'd like to burn. Its in .cue/.bin format, and I'm quite used to that. However, with SOME of the .cue/.bin files, they require a certain media. i.e. - a CDR/CDRW instead of a plain jane CDR. Heck, I even tried one of my old CDRW only cd's and it recognizes that, but says, "nope, gotta have a CDR/CDRW".
Is there any work around to this?
And no.. binchunker doesn't seem to be working with this one.
TIA!
Old Dec 23, 2002 | 07:19 PM
S2000boi's Avatar
upgrade
Old Dec 23, 2002 | 11:42 PM
Schatten's Avatar
Originally posted by S2000boi
upgrade
And this means? Sorry man, I'm trying to resolve an issue. This has nothing to do with upgrading anything.
Old Dec 24, 2002 | 09:14 AM
DJ Qube's Avatar
From what I understand, if the BIN or CUE files get renamed, they can no longer find each other. This could be the problem.
Try the "bin2iso" program. It doesn't have a pretty interface (DOS), but it will turn your bin and cue files into a single ISO file. You may have better luck with the ISO file.
Old Dec 24, 2002 | 10:35 AM
Schatten's Avatar
nope, sorry DJ. this is a specific issue with a set of bin/cue files that are in perfect working order. they are not renamed, nor do I need to rename them. and binchunker nor any other bin extracting app work like the one you mentioned. I'm only looking for a possible solution - perhaps where the info can be changed, wherever it is stored for the media type.
Old Dec 24, 2002 | 12:40 PM
pain462's Avatar
Did you use Nero to encode the file? If you came across it and it was already in VCD format try re-encoding it but not with Nero. I use a program called TMPGEnc Media Encoder...
What I have found that also works is if its in VCD format already, burn it as a regular data file and it'll work as a VCD.
Old Dec 24, 2002 | 01:06 PM
Schatten's Avatar
it was a downloaded cue/bin file - I'll check and see what I can do with Nero - that's what I've been using. I'll see if there are any other options to tweak with the files.
Also, if you have a VCD, its a .dat file - you can rename that to .mpg and it will play find through media player or just open the .dat file with media player. but thanks for understanding!
VTEC_Junkie
Feb 23, 2004 07:53 AM
s2kdriver80
Mar 31, 2003 05:37 AM
HondaGal
Dec 1, 2002 06:36 PM
