Question on a graphic image
Old Aug 9, 2001 | 10:14 AM
HondaGal's Avatar
Default Question on a graphic image
I received an email file from a new member.. it has the file extension .art Does anyone know what this is, and what software to use to convert it.
Old Aug 9, 2001 | 10:21 AM
Schatten's Avatar
".art Graphics (scrapbook) (Art Import)"
http://webopedia.internet.com/quick_ref/fi...extensions.html
just try to open it up in paint, photoshop, something of the sort.
Old Aug 9, 2001 | 10:26 AM
nova s2k's Avatar
I've never heard of a .art file ... neither has http://www.wotsit.org/ or http://www.extsearch.com/ which have a pretty good list of file formats ... are you sure it's not a .arj? That's a compression utility (like .zip).
http://www.computronics.be/courses/append/fileext.html says it's a First Publisher Clip Art file ... http://www.sillyeagle.com/fileext.html and http://www.ubak.gov.tr/Search/Resch/exteng.htm#A are two other lists of file extensions that have it listed ...
Of course knowing what it is and knowing how to open it are two different things ... I'd suggest a kind note to whoever sent the file to you asking them what it is ... how to convert it ... if they could convert it for you ...
Have fun,
Derek
Old Aug 9, 2001 | 11:03 AM
HondaGal's Avatar
I did email the person.. however they say they are not to techy inclined. Oh well.
I did try to open it is paint and photoshop with no luck.. it is a .art file for sure...
Not the end of the world.
Old Aug 9, 2001 | 11:13 AM
VisualEchos's Avatar
Did you peeps get that virus that comes around asking you to check something out? Seems as if it were the same type of file...
Andrew
Old Aug 9, 2001 | 11:49 AM
Palmateer's Avatar
The format that ends in the extension .ART is valid.
You should be able to open the file by selecting "File" "Open" in Internet Explorer.
Old Aug 9, 2001 | 12:54 PM
josh3io's Avatar
doesn't AOL have some sort of .art image file type?
Old Aug 9, 2001 | 12:57 PM
Schatten's Avatar
josh, I believe you are correct. IE requires that you install an AOL graphic extension plugin - just go to windowsupdate.microsoft.com and it should be there under product updates near the bottom.
Old Aug 9, 2001 | 01:00 PM
HondaGal's Avatar
[QUOTE]Originally posted by Palmateer
[B]The format that ends in the extension .ART is valid.
MrForgetable
Apr 4, 2004 03:52 PM
s2kdriver80
Mar 31, 2003 05:37 AM
