SD [memory] card failed for no reason
i got a panasonic digial camera running a toshiba 256MB SD card (SD-M256)
all of a sudden, the card failed to read and show an error message "card error". the system force us to format the card on start up of the camera. but an error message "format error" show up when we choose to format the card. (with the card still inside the camera)
i tried connecting the camera to the computer, but the computer can't access the card.
i tried the camera with another SD card and it works just fine.
so, can't access and can't format the SD card. i searched briefly on the web and nobody seems to be have a solution for it?!
the SD card fairly new, with less than 1/2 yr of useage.
what gives? anybody experienced the same thing? got a fix?
On SD is the gold exposed like on a Smart Media? If so then moving it in and out of the camera scratched it and made unreadable. If you can plug directly into a computer without the camera you may be able to salvage some of the files. I have Smart Media (Stupid Media actually) that you should not move in and out of readers as it is easily scratched. No more cameras that use it for me.
the bad sd card, does it work in anything else no/yes
NO, the bad sd card needs reformatting, look or post onto brighthand.com to find a routine that will formath these little things. just like a hard drive there are a few different formats so inquire which format too. the card itself may be bad, see if the manufacturer of the camera or sd card will do good.
YES, it does work in another computer, copy the directory structure from the good sd card onto the bad card
this sucks
even if i can reformat the card, but who knows it will fail again?
it will be really bad if it fails in the middle of a vacation and lost all the photo
i had some old smartmedia cards for my old camera and they lasted quite a while (and useage). one card acted funny sometimes when you first put it in, but another try or some usually solve the problem and it never lost the data.
i am using CF is my Canon and it never lost a beat
this new SD card thing sucks
There are some utilities that will do "raw reads" of the card, bypassing the file system and recover the files on it. I do know they exist for OS X and probably Linux.
The card will still be toast though. You might be able to recover some or most of your photos.
Here's a place to look for help:
http://www.ultimateslr.com/memory-card-recovery.php
Originally Posted by stockae92,May 23 2005, 10:30 PM
its not the write-protect switch, i've tried
the problem is the camera can't seems to recognize the card
hence the "card error" and "format error"
