Using the GTech Pro Idea
Just got my GTech Pro today. Haven't used it yet, but will soon do some testing to compare with when my SC is installed. Just finished reading the directions and have a thought.
Instructions tell how to do a 0-60 measurement. The problem with such a test is having a consistent launch so that driver errors could be eliminated. So....why not start at a speed above 0. I'm thinking, I'll start at 10 mph and floor it. No wheel spin, no clutch slip, only one place for human error - gear shift. I assume the GTech would measure to 70 mph and give me the elapsed time. It seems to me this would be a great and most accurate comparison in engine performance. Any thoughts?
here is why it wont work, to be at 10mph steadly you have to be at xxxxRPM but when you do a launch you are at xxxx+yyyyRPM so you have more rpm=more tourqe =faster times than 10-70, this is why 5-60mph times(standard for street start) are slower than 0-60 times
The real problem with my idea is that I would have no comparison on this or any other forum. I may have a good comparison before and after my mod, but would not know how that stacks up against the real world - 0 to 60! The more I think about this the dumber my idea sounds.
The Gtech deoesn't work this way. Essentially you have to set it at a stable state in order to measure relative acceleration. This includes getting it perfectly level as it will otherwise measure gravity and register this as an accelerative force. To set it correctly takes a lot of time even when the vehicle is sitting parked. To try and set it accurately at constant speed would be impossible even assuming you could maintain a constant speed of 10mph.
As per the previous post, I am not planning on 10 tests. I do want to have some mileage left on my tires when I'm done.
