crazy offsets only...
Old Sep 20, 2009 | 05:23 PM
  #2671
Terror's Avatar
Uh....
Old Sep 20, 2009 | 06:04 PM
  #2672
//steve\\'s Avatar
I love regamaster evo's....sooo hot.
Old Sep 20, 2009 | 06:40 PM
  #2673
tnep's Avatar
lol alex u need that camera asap
Old Sep 20, 2009 | 06:49 PM
  #2674
alexisthemovie's Avatar
i'm saving for a 16-35 II lens too
expensive hobbies own my bank account
Old Sep 20, 2009 | 07:40 PM
  #2675
Nick.'s Avatar
would 16x8 et11 be TOO crazy for the rear?
Old Sep 20, 2009 | 08:13 PM
  #2676
civic-si 2003's Avatar
^ nah you should be good to go
Old Sep 20, 2009 | 08:58 PM
  #2677
yes
Old Sep 21, 2009 | 12:25 AM
  #2678
fcpmarcus's Avatar
lol
Old Sep 21, 2009 | 03:11 AM
  #2679
Nick.'s Avatar
Originally Posted by fcpmarcus,Sep 21 2009, 01:25 AM
lol
sorry brah trying not to run the same wheels everyone else passes around on here.
Old Sep 21, 2009 | 06:34 AM
  #2680
ccdan's Avatar
Since offsets are dependent on widths (as that's how they're calcualated) it's hard to figure out fitment from wheel to wheel unless your using other simular setups as referance. If you want to figure fitment out the best was possible look at backspacing and frontspacing. You can find these out based off any wheel setup.
Backspacing: Is the distance from the wheels hub mounting surface to the very backside of the wheel.
Frontspacing: Is the distance from the wheels hub mounting surface to the very frontside of the wheel. (this is usually calcualted by taking overall width minum the backspacing)
Overall Width: Is the total with of the rim; backspacing + frontspacing. This measurement will be 1" wider than the rims actual width.
Actual Width: The distance from the wheels bead seat areas.
18x10.5 +24
Backspacing: 6.69" (overall width / 2) + (offset / 25.4)
Frontspacing: 4.81" (overall width - backspacing)
Overall Width: 11.5"
Actual Width: 10.5"
What does that all mean? By getting these measurements you can figure out how a wheel sits to the suspension as well as to the fender. Camber does play a roll as it's altering the space by angleing the mounting surface. So when your adding more frontspacing and deducting backspacing.
S2000's like 3.25" of frontspacing and can handle 8.50" of backspacing. What everyone on this thread is concerned with is frontspacing as that's how the wheels sit to the fender. 3.25" frontspacing would look weak with any sort of camber however with nothing and non rolled fenders it would sit really close. By rolling the fenders you get about 1/2" more clearance and with some camber you get even more. Seems as if the sweet spot is 3.75" to 4.25" of frontspacing. Which you decide is right for you will determine how much camber you'll have to run. The less frontspacing the less camber. You can also either gain more frontspacing or reduce the amount of camber by pulling the fenders.
16x8 +11
Backspacing: 4.93"
Frontspacing: 4.07"
Overall Width: 9"
Actual Width: 8"
Depending on your drop you'd have to run about -3.5 degrees of camber with ROLLED FENDERS to be able to tuck tire at which point you'll have ruffly 3.5" of clearance to the inner fender.
