crazy offsets only...
Old Nov 16, 2009 | 07:29 PM
  #3191
o'malley_808's Avatar
Originally Posted by Whitefire818,Nov 17 2009, 12:23 AM
^ run a 255 or 245 in the back and add more camber! Plus if you lower your car some more you can get more camber. Maybe get rear adjustable camber joints? If I were you I would just run a 255, more camber, and slightly flare the front and rear fenders.
Me and my buddy maxed out the camber on the oem adjustment bolts and bounced on the rear and the fender still bottomed out on the top edge of the tire
Im not going to sacrifice safety for function as I have 370whp and plan to turn up the boost in the next year so running a smaller tire is not the best idea for me just to get my wheels to fit in the fenders....
not to mention running alot of camber on such wide tires with high hp the tires will be camber wore in no time...
How much can the rears be pulled before body work needs to be done and does anyone have a link how it is done?
Old Nov 16, 2009 | 07:41 PM
  #3192
Whitefire818's Avatar
I think with how little the difference between a 255 and a 265 is you won't notice it. I'm not sure flaring your fenders out to the max will fit that. In your case I would go with rear overfenders.
Old Nov 16, 2009 | 07:54 PM
  #3193
Silencer_F22's Avatar
what will be needed to make 17.9 +45 245 all around fit?the car is stock height but i plan to lower it about 1"-1.5"
  #3194
lautll421's Avatar
9.5+28 front and 9.5+36 rear
Old Nov 16, 2009 | 08:14 PM
  #3195
alexisthemovie's Avatar
you need camber and 265's are oversquare on a 9.
Old Nov 16, 2009 | 09:01 PM
  #3196
fender roll and bumper tab relocation. People do it 24/7 with rpf1's. Easy stuff
Old Nov 16, 2009 | 09:03 PM
  #3197
thansk man. will it matter when i lower it or still it wont rub?
Old Nov 16, 2009 | 09:06 PM
  #3198
Originally Posted by Silencer_F22,Nov 16 2009, 10:03 PM
thansk man. will it matter it rub when i lower it or no?
you can mess up your front fenders if it rubs and when you turn they will get messed up if they hit, not to mention you will start to take chunks out of your tire if it hits the front fender while driving. Do the roll and bumper tab relocation first. I suggest while you're rolling the fenders to just flare them out as well. You'll be able to go lower and still have clearance to turn in the front.
Old Nov 16, 2009 | 09:10 PM
  #3199
so your 1st post was referring to stock height right?
Old Nov 16, 2009 | 09:30 PM
  #3200
TurboTanger's Avatar
Originally Posted by Whitefire818,Nov 16 2009, 08:16 PM
I think right now my fronts are flared to the point that they almost get wavy and I would say I have another 10-12 mm of clearance.
Do you do your own rolls and flares? and what are your current wheel specs?
