crazy offsets only...
Old Feb 8, 2011 | 12:24 PM
  #5531
alexisthemovie's Avatar
[QUOTE=Euroflavor,Feb 8 2011, 08:55 AM] I was just throwing it out there.
Local guy here had 11.5 +44 in the rear and said he was rubbing inside here and there, must have been on cornering?
Old Feb 8, 2011 | 02:32 PM
  #5532
Sticky2k's Avatar
Test fitting my wheels on my brothers car rubbed the suspension and brakes
Old Feb 8, 2011 | 04:53 PM
  #5533
drewschindler's Avatar
thanks guys! i wanna change the wheel color, but im still so unsure of what i want i was considering black gloss, but before that i was considering mag blue-ish or a close to navy blue(gloss of course)
Old Feb 8, 2011 | 05:16 PM
  #5534
barrett4bama's Avatar
I'm almost positive you should go with that color. It grows on me more everytime I see it with that GPW. It looks good dude.
Old Feb 8, 2011 | 05:36 PM
  #5535
NightRider's Avatar
Originally Posted by S2tripleO,Feb 8 2011, 04:08 AM
Thanks, car looks great! How do you find the ride/handling with that much stretch on the front end? Do you think with a degree or two more of camber up front you could have went to a wider tire?
Are you kidding? Wider tire + more camber? More camber = less contact patch. His setup is great as is.
Old Feb 8, 2011 | 05:48 PM
  #5536
moomoopanda's Avatar
Theoretically.. More camber means more contact patch around a turn. But decreased braking performance....
Old Feb 8, 2011 | 06:15 PM
  #5537
S2tripleO's Avatar
I'm sure an extra 30mm gained in contact patch going from a 225 to a 255 would make the slight amount of patch lost by an extra degree of negative camber negligible. He is only at -2 degrees in the front right now.
I'm asking because I want to run an 18 x 10 +40 with a 255 in the front, and I want to find out what it takes to do so.
Old Feb 8, 2011 | 06:18 PM
  #5538
fender work
Old Feb 8, 2011 | 06:19 PM
  #5539
00S2Ked's Avatar
riding dirty son !!!
Old Feb 8, 2011 | 06:23 PM
  #5540
Are you sure you are actually riding anywhere, or just crawling?
