How To's
Hey guys, trying to save some on money, have a garage where i keep my car, and tired of paying an arm and leg to have fluids changed. Work on the car a ton myself, didn't know if anyone had any easy "how to" guides for the rear diff and transmission fluids. have to change mine and want to save some. Thanks ahead of time guys. James
Check out the Under the Hood forum. There are the "how to" for both of these items.
My piece of advice is to buy one of those cheap little hand pumps from Autozone. Your hand will get very tired from squeezing those bottles
I have the little pump thing from Autozone. It has little barded tabs to hold it in the filler hole.BREAK THESE OFF BEFORE YOU USE THE PUMP. I was using my pump and one broke off.
I could not find it anywhere.
It appeared that it might have went into the tranny.
I flushed the tranny two times with nothing coming out.
I finally gave up and dumped the fluid to my recycle bucket and there it was in the bottom of the drain pan.
COVER YOUR ASS AND BREAK THEM OFF BEFORE HAND.
btw...there are two good threads with pictures on S2KCA
http://forums.s2kca.com/showthread.php?t=1...nsmission+fluid
http://forums.s2kca.com/showthread.php?t=10450
I finally gave up and dumped the fluid to my recycle bucket and there it was in the bottom of the drain pan.COVER YOUR ASS AND BREAK THEM OFF BEFORE HAND.
Originally Posted by ROGUE3308,May 7 2008, 04:17 PM
James, we can do this at my house. Just let me know when you want to do it.
If it's a weekend that I'm free, I can come down and help. After all the help from everyone last time, the least I could do is help someone else.
