Wheel Still Shaking :(
SO..
as some people know.. my civic shakes..
got the wheels balanced the other day, took it on the highway... nope.. not gone.. from 55 and higher, it's pretty bad... at 85.. my hands feel like they will go numb if i grip the steering wheel and longer..
any suggestions?
any suggestions?
Originally Posted by Mocky,Dec 28 2005, 07:05 AM
you mean just shake the wheel back and forth?
is this expensive to fix?
Its a civic nothing is that expensive
! It should not be that bad.
Originally Posted by Mocky,Dec 28 2005, 08:30 AM
SO..
any suggestions?
any suggestions?
Wheel bearing?
I know you got your wheel balanced but did they run it on a machine than can measure runout?
http://www.gsp9700.com/pub/technical/4127T/4127t.cfm
Originally Posted by efthimios,Dec 28 2005, 11:12 AM
did you ever do what I told you? most likely not...instead you'll bitch about it for another year like your V1
i have no idea what they used to balance it, but i'll find out more today
OEM Honda wheels or aftermarket?..........If aftermarket ;are the wheels hubcentric or require the inserts in the register bore of the wheels?
If they forgot to install the hubcentric rings no amount of balance weight will ever get the "shimmy" out.
If you have oem Honda wheels on and have bad vibs @ speed you have expensive issues to deal with
