Oklahoma S2000 Owners Oklahoma S2000 Community
Idle Stumble
Old Oct 23, 2005 | 09:31 PM
the_DZA's Avatar
Originally Posted by xlr8,Oct 23 2005, 05:31 PM
I did the MAP whack and reset the ECU and it fix the idle issue. I think I wll clean the TB as well. Any suggestions on what to use???
See man I tried to tell you.... Glad you got it all straightened out. As for TB cleaner, some people use injector cleaner mixed 5:1 with gasoline, I am sure that you could also use carburetor cleaner. I would use solvent resistant gloves either way if I were you.
Old Oct 23, 2005 | 09:33 PM
the_DZA's Avatar
Originally Posted by cliffdogg2k,Oct 23 2005, 04:27 PM
i noticed the same thing with mine. is it actually the throttle cable?
Bring your S2000 out Tuesday and I will fix everything wrong with your bogging Honda.
Old Oct 23, 2005 | 09:34 PM
the_DZA's Avatar
Oh by the way cliff here is an important link you should look at:
https://www.s2ki.com/forums/index.php?showtopic=282177
Old Oct 25, 2005 | 05:28 PM
vbmarcus's Avatar
I used to have the same problem... .but after 8-ball tightned my "granny slack" and I lubed the throttle cable... the problem has subsided... course.. .I don't drive my S much... so I don't know if this really fixed it.
Old Oct 25, 2005 | 06:56 PM
cliffdogg2k's Avatar
yup, i see, im glad i run premium now....
Old Oct 25, 2005 | 07:04 PM
esoteric's Avatar
Be careful w/ carb cleaners etc...
Depending on the product they can damage your sensors. Map, IAC, TPS, etc...
Seeing as the weather is starting to change and it seems to be flacuating, it very well could be your idle air control thermal valve. 99-00 Si's had this problem, hadn't really heard about it on the S2K.
Jp
Old Oct 26, 2005 | 02:52 AM
rehile's Avatar
Had this problem once, too. Never did figure out the exact problem, but I did the MAP whack a couple times. It stopped sometime after that.
Others in our area also posted on this (see link)
Ramses19912
Jul 8, 2011 03:00 PM
n3o729
Aug 9, 2008 07:59 PM
98TypeR#21
Jun 15, 2005 06:20 PM
s4play
Jun 15, 2004 02:45 PM
nastinupe1
Oct 2, 2003 10:23 AM
