UGHHH SOMEONE HELP!
Sorry... I hope nothings wrong or at least its easy and cheap to fix if their is
I still cant get my stupid radio to work
Gona try and con circutcity into fixing it though. If you buy a head unit from them they say they will install it for free.
If youre around the south side area ill install it for you as long as you get the harness.
Lee will take care of you or do is best to, i have personally been up there and wont go anywhere else anymore. You should still be under warranty also, so they will take care of it. Joe marina wanted that much to listen to my car tick when the tensioner was bad. Good luck, keep us posted.
damn! not cool
hopefully its nothing serious.
sounds like that 2nd gear TSB to me (except its happening in 1st gear).
do you know what tranny fluid is in it? shitty tranny fluid or worn out tranny fluid can make your tranny do all kinds of weird shit. i'd change the tranny fluid with the updated honda mtf (i just did mine a couple of weeks ago, and i noticed a quite a difference in shifting. much smoother)
and also, some of the buzzing could be your clutch (although all of the newer s2k's are supposed to have the updated one). check the tsb for that on here.
hopefully it can get covered under goodwill consideration, but i wouldn't hold my breath. that shit is pretty rare from what i've heard.
hopefully its nothing serious.sounds like that 2nd gear TSB to me (except its happening in 1st gear).
good news. well i took it to honda. he tested a bunch of stuff and put it on the lift, he said that sometimes they just pop out of gear. since it hasnt happened since that one time. not to worry too much. but if it starts happening some more then come back and see them. but they think the vibration noise is coming from something behind the dash. like a washer that is loose or something. im gonna tear a couple things out off the motor and see if something is just loose on there.
but all seems good so far! yay for not having to buy a new tranny
