Help with running lights :)
Old Jun 19, 2011 | 12:37 AM
Tomoizle's Avatar
Default Help with running lights :)
Today during the Newport drive Steffan mention to me that my rear running lights don't work. My question is that my further most rear tail lights stays on is that consider a running light on a 2000 ap1? My brake lights and everything works fine I checked the fuse small lights and it was perfectly fine.... Can anyone here clarify this situation? If anyone has a 2000 ap1 can you turn on your headlights and see which tail lights light stay on?
Old Jun 19, 2011 | 06:19 AM
phongs2000's Avatar
Tommy,
I don't know what year Steffan's car is, but his 2 round tail lights are definitely on. During the drive, I thought you had tinted your tail lights because they were so dark. Didn't know it was broken.
Old Jun 19, 2011 | 06:34 AM
Tomoizle's Avatar
Found out from another 2000 ap1 it's not broken lol my driving lights are the two lights on the outer most not where the brake light is suppose to be
Old Jun 19, 2011 | 07:50 AM
EVAN&MONICA's Avatar
The rear tail lights are a dual filiment bulbs, they may still come on when the brakes are applied but not when the headlights are on, you most likely just need to replace the main bulbs in your tail lights
I learned this a while back after a night drive when I had the same issue I think your trying to describe and Ira was having to work double hard not to rear end me
Old Jun 19, 2011 | 10:15 AM
#172CR's Avatar
Evan that's great advice, I didn't know they were like that. I remember my civic was like that. You really don't know because when you step on the brake the lights still work.
Old Jun 21, 2011 | 11:05 PM
Tomoizle's Avatar
Just replace the bulb? Is it a coincidence that it happens on both side? I check the small light fuse and it looks good so i know it's not the fuse.......
Old Jun 22, 2011 | 07:57 AM
Its a common coincidence, I guess. Mine both went out at the same time as well.
Old Jun 22, 2011 | 08:53 AM
Tomoizle's Avatar
So just replace both the brake light light?
Old Jun 22, 2011 | 08:57 AM
#172CR's Avatar
Just replace the bulb and you should be good. When you pull out the old one you should see two filaments inside the bulb. And I bet one of those filaments is broken.
Old Jun 22, 2011 | 10:35 AM
Artisyn
May 4, 2014 09:02 PM
phil121081
Car Talk - Non S2000
45
Dec 10, 2010 09:56 AM
manolo.cabasal
Jan 4, 2010 05:11 PM
bigk
Mar 3, 2006 01:27 PM
Elistan
Sep 5, 2004 08:06 PM
