New Clutch needed?
Old Nov 9, 2010 | 11:38 PM
smach's Avatar
Default New Clutch needed?
When I'm at a stop the car seems to chirp/squeak.. But when i push in the clutch, the chirp/squeaking goes away.. after the last photo shoot some of the guys said its probably the clutch bearings being worn.. and if im going to replace it i might as well get a new clutch.. what is the best bang for the buck for clutch replacement? (might aswell upgrade to a light weight flywheel while im at it )
I have not tracked the car and don't plan on going hardcore power upgrades with this car because it is my daily. just something reliable and inexpensive.
is this on craiglist a good deal?
http://portland.craigslist.org/mlt/pts/2044735098.html
Old Nov 10, 2010 | 12:18 AM
ghettocrxsi's Avatar
Bad deal, you could spend a little more and get a Science of speed clutch or act or clutchmasters.
New setups for n/a power are around 650.00+ or - depending on what your looking for.
Then you need to figure out if your going to install it or have someone do it. Its not a bad job I have done 5-6 of them.
Old Nov 10, 2010 | 05:42 AM
#172CR's Avatar
Steven you could also swing back by forged if your ever out in the area and have them take a listen as to what it is too, just to make sure.
Old Nov 10, 2010 | 07:38 AM
Webfoot's Avatar
Not trying to ninja the thread, but on this very topic.. When my S2K is cold in the morning 2nd gear can be a bear to get into. My S2K is a 05 w/ 40k miles on it, is this a sign my clutch is getting ready to die?
Back to the normal programing....
Old Nov 10, 2010 | 08:03 AM
Sabre's Avatar
when was the last time you changed your trans fluid, Walt?
Old Nov 10, 2010 | 08:05 AM
Webfoot's Avatar
Never since I have owned it. Only fluids I have changed is the oil.
Old Nov 10, 2010 | 09:00 AM
Sabre's Avatar
Try changing the trans fluid to something like GM Syncromesh or the *new* Honda MTF. It might solve your problem. If it's original fluid @40k miles, you're well due for a flush.
Sorry for the threadjack
Old Nov 10, 2010 | 05:15 PM
G's Avatar
G
yes you are - and that is typical sometimes of a cold tranny, not a bad clutch.
I would make sure I get a second POV from a pro before putting in a new clutch, it could be something else, and easier/cheaper to fix.
Old Nov 11, 2010 | 09:35 PM
smach's Avatar
Alright ill check it out.. i should probably change the trans fluid too.. haven't done that yet. bought it with 61k, and i dunno when the last person changed it.. shouldn't be too hard right?
Old Nov 11, 2010 | 11:23 PM
nv_blitz's Avatar
I think i have a discount coupon for a SOS clutch kit that I got from homecoming II, I will look for it and let you know.
I had a clutchmasters clutch and there light weight flywheel really nice products... i suggest you add a light flywheel when you do the clutch too
