Rag Top Replacement Recommendation
My 2000 ap1 is in need of a new top. I am looking for a recommendation on where to purchase a new top and a recommendation for a shop in the Portland area to do the install.
Check the classifieds section, Hiep is selling his soft top;
Ron Tonkin Honda has a pretty good reputation as far as quality installs for the soft top.
i have not seen the robins brand tops in person, I have seen 3 different brands of the tops you see all over ebay 450-650 dollars. And the stitching is horrible and the fabric is sewn in a different pattern than oem and looks weird after 6 months they all began to tear..
If robins or ez is a good brand go with them. Stay away from ebay.
If you were closer to yakima i'd help you install your top. I installed mine and honestly it wasn't too difficult, just very time consuming since I did it by myself. I had a plastic window that cracked and wanted to upgrade to a glass window. After I received a quote for $1700+ for a new robbins top including install, I decided to save some money and attempt it myself with a used OEM AP2 top that I bought from a member on the marketplace forum. Its much nicer than the plastic window and it came out wonderful!
I been thinking about doing the work myself. It looks likes a tedious project, and a test of patience. How long did it take you to complete the work? My thoughts are to go with the top from auto top direct. they use Stayfast material with a glass window for $600.00. I've gotten one quote for $650 for an install. I plan to check Brights, heard they do good work. I will also check Ron Tonkin.
What directions did you follow to do the install? Any advice would be helpful.
Thanks,
Thanks,
$700 firm.
