Rag Top Replacement Recommendation
I been thinking about doing the work myself. It looks likes a tedious project, and a test of patience. How long did it take you to complete the work? My thoughts are to go with the top from auto top direct. they use Stayfast material with a glass window for $600.00. I've gotten one quote for $650 for an install. I plan to check Brights, heard they do good work. I will also check Ron Tonkin.
What directions did you follow to do the install? Any advice would be helpful.
Thanks,
Thanks,
It took me two days (did it on a free weekend). I'm sure it could be done in a day, but I took my time and was in no hurry since this was my first time attempting anything of this nature and I was scared to mess something up. Do you already have a glass top? If so it should save you the work of having to modify the frame and drilling holes in the bows to add the elastic bands. The instructions are pretty straight forward and I didn't get stuck at any point. If you do attempt this make sure to keep track of all the nuts and bolts so u don't end up missing any once u put the car back together. If you do decide to do it yourself, let me know and i may be able to help u if its on a weekend
When I went to the local dealer they also told me that they don't actually do the tops themselves, they have some other shop do it for them.
Thanks,
Thanks,
Thanks for the information. Who did you purchase your top through? I'm learning towards Auto Top Direct. Called Tonkin, they told me to call Beaverton Upholstery.
I have labor quotes from $500 to $1150. Still learning towards doing the work myself.
I purchased the OEM top used from a texas member who decided to go with a hardtop. If you search the marketplace forum I'm sure you will find someone selling an oem top in good condition. It will probably be about the same price as an aftermarket to but I dont know what their quality may be like
I have started on the install. I believe the top that I am removing was not installed correctly. The top was attached to the inner most side of the rain rail. I would believe that it needs to be attached inside the rain rail. Can you verify if this is correct?
Thanks, I did find a diagram showing the install at the rain rail. Just about have it done. I will have about 10 - 12 hours into the job working solo. I believe a shop could do the job in 4 hours without much problem. So some of these shops are making a killing on the labor. Now that I have done one, I think I could get the job done in about 8 hours.
Seven11
Apr 24, 2013 10:19 PM
