Random Talk 2010
Old Jan 23, 2010 | 04:37 AM
  #171
id003's Avatar
I just got a set of the CR wheels. So 7" and 8.5". Will theyre be much of an issue with that.
Old Jan 23, 2010 | 07:54 AM
  #172
H2kBBAP2's Avatar
You wont rub at all with CR wheels, they are the stock offset. You can just put them on bro.
Old Jan 23, 2010 | 03:30 PM
  #173
id003's Avatar
Yeah im not worried about rubbing. What im really debating is whether to run a 215 or 225 up front. Id like that a 225 will fill my wheel well a bit. And i figure that itll provide more grip, but are there any downsides i need to consider?
Old Jan 23, 2010 | 04:16 PM
  #174
S2000 Cabrio's Avatar
i think the only downside is the price and the diameter will be bigger so it will be a bit heavy. ...try to go to tirerack.com and find out the specs of the width of the tires and compare....then you'll know what i'm talking about.
Old Jan 23, 2010 | 05:16 PM
  #175
G's Avatar
G
I am not sure, but if you put more grip on the front, will that make the rear break easier?
Old Jan 23, 2010 | 05:29 PM
  #176
EVAN&MONICA's Avatar
In short yes
Old Jan 23, 2010 | 05:48 PM
  #177
Backspin23's Avatar
Not necessarily easier...It will still have the same grip and require the same amount of force to break it free...however the front will have more grip and therefore you'll be able to produce a greater amount of lateral g-force.
Old Jan 23, 2010 | 07:25 PM
  #178
s2sik's Avatar
are you referring to the rear breaking loose, or the rears braking easier? if its the second, i agree with evan if its breaking loose then no.
Old Jan 23, 2010 | 07:31 PM
  #179
Backspin23's Avatar
Helps if I read the question before jumping to the funnest solution.
Old Jan 24, 2010 | 06:19 AM
  #180
G's Avatar
G
breaking easier - more grip front means the same grip rear will net less grip -
