Orlando The I-4 Parking Lot
Weird noise?
Old Apr 20, 2010 | 05:37 AM
blkt1rod's Avatar
wish i could say the same lol but no mine has to be a worn out diff >.<
Old Apr 20, 2010 | 07:08 AM
tony2k's Avatar
whats ur milage? was that thing beat on that u kno? sounds like a problem someone caused b4 u...
Old Apr 20, 2010 | 07:29 AM
blkt1rod's Avatar
I'ts got 54xxx on it now when i got it about 48xxx and to my knowledge im not sure if it was beat on but then again you never know definitely wasn't something caused by me i rarely ever get on my car so it was a problem that started from the get go.
Old Apr 20, 2010 | 07:37 AM
tony2k's Avatar
yea it happens...atleast its getting fixed!
Old Apr 20, 2010 | 07:49 AM
blkt1rod's Avatar
Yea your right so as soon as i find one i will be looking to get this fixed
Old Apr 20, 2010 | 08:24 AM
tony2k's Avatar
become a member and go sell some stuff on the board or trade wat u got for one...ppl dont look 4 u...u gotta look 4 them...to get a diff that is..
Old Apr 20, 2010 | 09:27 AM
blkt1rod's Avatar
k thanks and this is what I've found so far
Stock build,
A clean reconditioned rear using stock OEM parts and a stock 4.10 gear ratio is $750 plus shipping
A Stage 1.5 is a rear that will have cryo treated bearing caps, hardware, and gears. The rear will also have a Heavy Duty (not stock) crush sleeve and a balanced assembly. The crush sleeve used in this rear is over 50 thousands heaver than a stock crush sleeve and will hold up much better than the stock unit.
Price for this build with a stock 4.10 gear ratio is $950
PuddyMod Stage 2 Differential for Honda S2000
This build is your best bang for the buck in a upgraded and enhanced diff.
This rear has a 100% none failure rate and is ideal for N/A and cars with forced induction up to 350 Horse Power.
PM Stage 2 rear build,
The rear is set up for N/A and low boosted cars.
It is rebuilt from the housing in starting with every part being cryogenically thermo cycled, then new pinion bearings and seals are used to assemble. There is a one piece PuddyMod solid steel sleeve used instead of an OEM crush collar. The solid sleeve is made of 10/20 mandrel steel, it is seamless and will not compress under heavy stress like the OEM can. Solid sleeves are used in high performance drag racing rear ends because they work. The PM sleeve is a custom made part to fit this rear, it is a one piece steel sleeve. The stock hardware is replaced with new 10.9 hardware. Backlash is set at 2 to 3.5 thousands giving a tighter gear to gear fit.
Full Blueprint assembly of rear using precision accuracy to better than factory tolerances.
Price for the standard PM Stage 2 rear using a stock 4.10 gear ratio is $1,560
Old Apr 20, 2010 | 09:35 AM
tony2k's Avatar
damn...thats for some crazy ass power! id find one on the boards b4 i spent that kinda chetta
Old Apr 20, 2010 | 10:07 AM
blkt1rod's Avatar
i seen some on there for 500$ but he also takes your blown diffs or diffs that are worn like mine
Old Apr 20, 2010 | 10:13 AM
tony2k's Avatar
damn.....its up to u bro
