DIY Rear Diffuser.....Finally Done!
Originally Posted by UpsFella,Nov 18 2009, 07:22 PM
so do you have any pointers you would like to share? would you happen to have a template of diffuser you made, and if you were to do it all over again, would you use the same materials?
I am thinking about making a front bumper under panel and a rear diffuser, but i am leaning towards aluminum.
Unfortunately I do not have a template. My orginal plan was to use the cardboard as my template, but I soon found out that it was too flimsy when I started laying the fiberglass, so I decided to just lay the fiberglass over the cardboard instead.
If I were to do it over again, I would most likely use plywood or a thin type of wood for the mold, so that it would be stable enough to hold its shape for the fiberglass. It would also be much lighter as well.
I guess you can go with aluminum as long as you have a bending machine or a welder to put it together or you're be paying someone to do it for you, unless you have a hookup. It also may be a little heavy depending on how big it is
.... maybe junky can chime in with the aluminum stuff since he's done it for his car.
Yeah I will say that 1/8" aluminum is light and can be worked/ bent if you have the right tools, I did not so I had to sub out some of those pieces and it gets expensive quick, better to do it all yourself if you can. Rivets actually work very well for attaching fins etc and are hidden/flush and light vs bolts or getting into welding which would be a whole other deal, but if you can weld aluminum yourself then great, it will ad more weight then a few rivets though. Once I put all the individual pieces together and mounted to make sure fitment was exactly where I wanted it, I removed and took to get black powder coated and re installed. I’ve had it on the car for about a year now, I’ve been quite happy with the mounting and powder coat. Everything has been trouble free and held up nice.
I'm currently in the beginning design faze of additional diffuser pieces to fit behind the rear wheel openings. As of now my diffuser just covers the main trunk area between the pipes.
Originally Posted by allnamestaken,Nov 19 2009, 11:54 AM
