Engine pinging
Old Aug 25, 2007 | 08:51 PM
MSRS2K's Avatar
Default Engine pinging
I'm getting pinging from the engine at low RPM (2500 - 3500) and mid to full throttle (of coarse), but no CEL light. Any suggestions how I should go about diagnosing this? It was my understanding that engine management would detect this and retard timing to prevent it. So whatever sensor(s) are used to detect this must not be working, but that would trigger the CEL, right? What am I missing?
Also FWIW, I'm getting quite a bit of soot on my exhaust tips.
- Michael
Old Aug 25, 2007 | 09:27 PM
PepCsS2k's Avatar
- Michael
didn't use premiun unleaded? Used super instead? That's my guess
Old Aug 25, 2007 | 11:45 PM
RT's Avatar
RT
Wow, if what you are hearing is indeed detonation be really careful. Detonation is pretty hard to hear on this engine so it's got to be severe if you are easily hearing it
If the sound isn't really pinging, it might be the timing chain tensioner deal.
Good Luck!
Old Aug 26, 2007 | 10:49 AM
MSRS2K's Avatar
Hmmn, it's not a mechanical rattle like the timing chain tensioner is described. It's more like a ping or ring from the engine. And it's only in that RPM and throttle range. Seems less pronounced after the engine warms up. It's easily audible, but maybe I'm just tuned to it now.
Old Aug 27, 2007 | 09:38 AM
madkimchi's Avatar
your cel should blink everytime there is knocking. and that sensor is EXTREMELY sensitive. r u sure you are hearing the knocking? if you are 100% sure its knocking take it to a shop right away. knocking will destroy your motor.
Old Aug 27, 2007 | 10:13 AM
RT's Avatar
RT
are you sure about the blinking CEL thing? is it only on AP2's maybe?
Old Aug 27, 2007 | 11:26 AM
MSRS2K's Avatar
I'm sure I'm hearing what I'm describing. I'm not sure the cause. I'm sure the CEL is not coming on.
I'm open to other suggestions as to the cause of the noise. I just don't know of any other potential causes, nor how to diagnose.
Old Aug 27, 2007 | 11:35 AM
mikegarrison's Avatar
Good Luck!
If the TCT is bad it still should only be making noise when the oil pressure is low.
Old Aug 27, 2007 | 01:29 PM
RT's Avatar
RT
..... you still sore about the insurance thing?
Old Aug 27, 2007 | 01:56 PM
bahula03's Avatar
...strike 3?
