Local place to get an alignment
Old Oct 9, 2004 | 12:20 PM
MaxGeek's Avatar
Default Local place to get an alignment
Can anyone recommend a local place to get an alignment? Around Renton to Bellevue.
Old Oct 9, 2004 | 12:25 PM
BBY2KS2K's Avatar
I hear Omni Brake and Alignment in Kirkland is really good.
Old Oct 9, 2004 | 06:37 PM
mikegarrison's Avatar
I had an outstanding experience at Group2 Motorsports, near the Ballard locks.
Old Oct 9, 2004 | 07:11 PM
MaxGeek's Avatar
Thanks, has anyone tried the european alignment?
Heres a thread on it.
https://www.s2ki.com/forums/index.php?showt...03&hl=alignment
I think its something I might try.
Also how much do alignments usually run?
Old Oct 9, 2004 | 07:32 PM
Yes.
Here are the "actual" numbers from my last alignment:
(note: 200 lb in driver's seat, 100 lb in passenger seat -- I decided to split the difference between having a passenger and being solo)
LF: -1.02 deg camber
6.45 deg caster
0.02 deg toe (in)
RF: -1.07 deg camber
6.48 deg caster
0.03 deg toe
LR: -2.02 deg camber
0.09 deg toe
RR: -2.00 deg camber
0.08 deg toe
I've been quite happy with it and my instructor at Proformance complimented me on how well the car handled with it.
Here's what I told them to try for:
Front: as close to 0 toe as possible, but err on the side of toe in rather than toe out (thanks for the tip, Ray...); -1 to -1.25 deg camber (target -1 but err towards more); 6.5 deg caster (+/- 0.25 deg)
Rear: 1/4 inch toe in (+/- 1/8 inch), -2 deg camber (but err torards more)
Old Oct 9, 2004 | 07:47 PM
RT's Avatar
RT
Old Oct 9, 2004 | 08:35 PM
MaxGeek's Avatar
Thanks for the settings mike.
How would I adjust your settings for a 130lb driver and no passenger?
Old Oct 9, 2004 | 08:43 PM
Just tell them to do the alignment with 130 lb in the driver's seat, that's all.
Old Oct 10, 2004 | 10:14 AM
MaxGeek's Avatar
Sweet thanks.
Old Oct 10, 2004 | 01:33 PM
lig's Avatar
lig
hi50 and I both had good experiences @ Europa in Bellevue.
Got the specs I wanted
-1.57 F 7.05 Caster zero toe
-2.6 R slight toe in - (forgot exactly how much )
