Need help diagnosing a problem!
Old Jul 20, 2010 | 02:20 PM
DiamondAp1's Avatar
Default Need help diagnosing a problem!
Hey I have the dealership stumped about my problem with my 08 wrx. So I wanted to see if anyone could help me here.
I hear a ticking noise when I'm in idle and when I'm driving. The frequency of the ticking noise increases as I increase my speed and vice versa. The only time the noise goes away is when I push the clutch in. When I release the clutch, the noise comes back. Any ideas??? I would appreciate any help!!! Thanks!
Old Jul 20, 2010 | 02:29 PM
kelvin96gsr's Avatar
does you feel any weird vibrations coming from the clutch pedal?
Old Jul 20, 2010 | 02:48 PM
DiamondAp1's Avatar
nope, everything seems normal other than the odd noise
Old Jul 20, 2010 | 03:46 PM
SuzukaBlade's Avatar
might have something to do with your valves? have you tried opening the valve cover to see if the noise is more distinct? could be sum sort of pump...
Old Jul 20, 2010 | 05:39 PM
UpsFella's Avatar
aftermarket clutch?.. some of them are really noisy!
Old Jul 20, 2010 | 10:19 PM
vspc2nr's Avatar
I smell a crank walk..........
Old Jul 21, 2010 | 12:00 AM
jason@psi's Avatar
Its possible the throw-out bearing could be the cause of the noise you are hearing. What is the history on the clutch and TOB
Old Jul 21, 2010 | 12:15 AM
RT's Avatar
RT
If you just slightly push the clutch pedal in does the noise go away or do you have to fully depress the clutch to stop the noise?
Old Jul 21, 2010 | 07:16 AM
DiamondAp1's Avatar
no I haven't tried that
[QUOTE]UpsFella Posted on Jul 20 2010, 05:39 PM
Old Jul 21, 2010 | 11:13 AM
RT's Avatar
RT
If you barely push the pedal and it goes away then it most likely the TOB and it's probably not worth doing anything about until you need a new clutch ..... in fact, the noise might go away at some point on its own.
If the noise doesn't go away until you go deep, then the problem is potentially tranny related (intermediate shaft bearing).
Doubtful it's Crank Walk but who knows.
Is the noise gone with the clutch pedal depressed when the car is parked, rolling or both?
