Quick alignment question
Old Mar 28, 2006 | 10:49 AM
Spa4eva's Avatar
Default Quick alignment question
Hey guys,
I'm getting my alignment done at Europa this thursday. I did a search and got Rob's settings from the wheel forum.
Front
-1.35 degrees Camber
0 degrees Toe
6 degrees Caster
Rear
-2.0 degrees Camber
0 degrees Thrust Angle
3.0 mm total Toe In......that would be 1.5 mm right and 1.5 mm left for a total of 3.0mm
Rob, obviously you like these settings. I was just wondering how worn your inside edges get compared to your outside with the -2 camber. I don't feel like changing tires quickly due to significant inner tire tread loss.
What would you guys recommend? I'm getting my alignment on thursday. TIA
-John
Old Mar 28, 2006 | 10:58 AM
tukluc's Avatar
Dont forget that Rob is part of the 2853018 club.....not sure if that affects your camber/toe settings.
Old Mar 28, 2006 | 11:02 AM
Spa4eva's Avatar
^^ hey good point. I'll stop by taco's tonight to talk alignments In the mean time, chime in with what you guys use as your alignment settings if you know them.
Old Mar 28, 2006 | 11:14 AM
jerrypeterson's Avatar
Non-zero toe settings will have a greater effect upon tire wear than camber. The alignment settings in this post are mild settings so I wouldn't really worry about tire wear.
Old Mar 28, 2006 | 12:49 PM
aronparsons's Avatar
If it's only street driving you'll be doing, you could probably go with a little less negative camber (-0.5f,-1.5r) if you're really worried about inner tire wear. The toe settings will have the biggest effect on tire wear; from what you listed, you'll be just fine.
Edit:
My current settings are (F/R):
Toe 0/.125"
Caster 6/na
Camber -1.5/-2.0 (should have gone -2.5 in the rear)
Those work great at auto-x with an otherwise stock suspension. That Saner FSB induced way too much understeer with only a 205/245 stagger. Gotta wear these RA-1s out quicker....
Old Mar 28, 2006 | 01:09 PM
WyattH's Avatar
I'll find the exact numbers, but people seem to really like the UK stock alignment settings. That is what I think I will be going with.
Old Mar 28, 2006 | 01:22 PM
WyattH's Avatar
One set I came up with, I'll look for the specific UK though.
2.1.3 ALIGNMENT
A proper alignment is important for autocrossing, and compared to the other changes you'll be making, a bargain at less than $100. Individual alignments vary, but for the
Old Mar 28, 2006 | 01:34 PM
WyattH's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry5767102
https://www.s2ki.com/forums/index.php?showtopic=44573
https://www.s2ki.com/forums/index.php?showt...80&hl=alignment
Haha sorry.
Old Mar 28, 2006 | 03:35 PM
Spa4eva's Avatar
Hey I appreciate the forums searches and input. Hope to see everyone else at taco's as today is a beautiful day to drive the S.
Old Mar 28, 2006 | 07:29 PM
RT's Avatar
RT
John, I always get just a touch of Toe-In on the front. I'd call it 0+ just to avoid toggling through zero due to geometry changes and the normal amount of play in the system.
Are you lowered? If so, go a little less camber on the rear than -2.0 (maybe -1.65 if you're going w/ -1.35 in the front) since you get neg camber earlier in the stroke when lowered ......... unless you need the excessive neg camber to clear some ill fitting wheels or some sh!t
BTW, Rob runs 285's too, what lame a$$e$ don't
