Rpf1's
Yeah I agree its a good choice if you like the concave look front to back. The 245 will help a little in clearance, but still plan on rolling your fenders front and back and more aggressive camber up front will be needed over a typical street set up. Plan on running -2.5 up front, less aggressive can be had in rear if you choose. I prefer the sharper turn in of more camber up front anyhow, which is more appreciated certainly if you run a wider tire up front such as a 245 or 255. Will be a nice balanced set up on an Ap2.
Sounds good. Yes I so plan on getting my fenders rolled. I'm going 17x9 all around because I can't stand the convex spokes.
Do these specs look good? Got them from someone running a 17x9+45 setup
front camber: -2.0
rear camber: -2.5
front toe: 0
caster: 6.0
rear toe: .15 total
front camber: -2.0
rear camber: -2.5
front toe: 0
caster: 6.0
rear toe: .15 total
front camber: -2.0
rear camber: -2.5
front toe: 0
caster: 6.0
rear toe: .15 total
front camber: -2.0
rear camber: -2.5
front toe: 0
caster: 6.0
rear toe: .15 total
S2GARAGENYC
Jul 26, 2015 03:44 PM
