Timing CHAIN issue?:(
Old Jul 16, 2007 | 07:28 AM
HeyDanNiceShot's Avatar
Default Timing CHAIN issue?:(
I've got a nasty noise coming from the front side of the motor which I now have no idea what it is. So naturally I've stopped driving it and I need to get it checked out before I go any farther. I've got no loss of power, so I'm assuming that's good news. Any suggestion on where to take it or if you've done it, what's involved?
Old Jul 16, 2007 | 07:55 AM
WRS2K's Avatar
describe more
Old Jul 16, 2007 | 08:00 AM
Originally Posted by WRS2K,Jul 16 2007, 07:55 AM
describe more
Kind of hard to describe really. At first I thought something was hitting my fan, then I pulled over to check it out, and the sound appears to be coming from the front side of the motor, under the valve cover. Like I said, no loss of power or anything. I don't hear it as much under load, but when I let off the gas at 3-7k it's pretty obnoxiously loud. Oil level is good, coolant level is good, car feels just fine. Wish I had more to describe it, because I'm not really looking forward to paying for the repair. (71k on the car, never a problem until now)
Old Jul 16, 2007 | 08:10 AM
mikegarrison's Avatar
The S2000 has a timing *chain*. I'm sure that's what you meant, right?
The tensioner usually only makes noise at startup, because what happens is the spring inside gets weak. After startup, though, it is mainly powered by oil pressure.
I would pull the valve cover off and inspect the valves.
Old Jul 16, 2007 | 08:23 AM
Guess digging a little deeper would have made me sound a bit like less of an idiot. Anyway, nasty little noise - not too happy about it, step one will be pop the valve cover I guess.
Old Jul 16, 2007 | 08:35 AM
RT's Avatar
RT
are the spark plugs tight?
Old Jul 16, 2007 | 08:36 AM
Yeah, check that too.
Old Jul 16, 2007 | 01:31 PM
WRS2K's Avatar
with your additional info, it's not the noise i had a couple of times which was the tensioner since mine only happened at start-up... once tensioner replaced, all good. but that sucker failed twice on me.
Old Jul 16, 2007 | 02:27 PM
RT's Avatar
RT
........ only "failed" once on me and I been running on it for the past 30k miles w/o issue (doesn't seem to get much worse once it peaks after a couple months)
SalvagedS2k
Aug 5, 2012 05:05 PM
Kumbi
Nov 3, 2011 05:45 PM
CarbonYellowJ's
Sep 12, 2008 11:38 AM
dctor
Jun 29, 2008 08:43 AM
speedy4cyl
Mar 26, 2004 07:34 AM
