Post Processing 4 Dummies
Sharpening is a deep topic by itself. I used to spend hours working on masks for multiple sharpening layers (radically different USM settings and edge-selection) but I get almost the same results in one minute with Photokit Sharpener and simple adjustment of its output layers.
Mocky, check your image "Mode." IIRC, if you are working in 16 bit you cannot use most filters.
Originally Posted by Dark_Sub_Rosa,Dec 6 2006, 09:36 PM
If you are getting noise from sharpening you might want to back off the sharpening just enough to not get noise.
Still can't do it
Somtimes I hate how the pictures come out of the camera, with very dull colors. Here's one picture that I thought came out good out of the camera:
Here is my edited version:
I do this by using several layer adjustment tools along with dodging/burning the areas as necessary.
Dodging/Burning are awesome, but that might be getting a little too advanced for Mocky right now because the best way to do that is with layer masks. Unless you're just "painting" a burn/dodge in.
He first needs to learn how to use layers, and then realize what the different adjustment/fill layers do. There's also learning how to organize layers - how many times have you been lost in the Layers/Channels/Paths section?
By the way, another cool way to effect the background is to throw a light gradient mask on it then give it a small gaussian blur
