Question, Need Help
I recently shot some pictures in RAW, when i hooked my Camera up to my computer, the computer tells me it has no pictures, or it doesn't recognize the file type. Im assuming this is cause i just recently starte shooting in RAW, cause this never happened before. Any help would be appreciated. Thanks.
You need to download Adobe Camera Raw. ACR 3.7 supports the 5D.
http://www.adobe.com/products/photoshop/cameraraw.html
I've also discovered that if you install another Adobe or certain Macromedia products after you've installed CS2, you will have to reinstall your RAW plug-in. There is literature about it on Adobe's website, but you have to search for it. I just reinstalled Premiere and learned this the hard way
Have you installed anything new since you installed Photoshop CS2?
Thanks for your info guys
Not sure what the issue is, but photoshop should recognize the files. If you just want to view the RAW files as thumbnails and open to view (just like jpeg's), go to microsoft.com and type "RAW thumbnail" into the search box. Once the new page opens, download the RAW Image Viewer. It looks and works the same way as opening a folder with jpeg files. That way you can sort through the junk faster.
$.02
$.02
Originally Posted by S2K000,Feb 22 2007, 11:15 PM
yea i have, but various programs, i use alot of stuff like Maya 7.0, Corel Painter, Adobe Illustrator, Indesign, etc.
, im gonna see if i can figure it out
Originally Posted by Poindexter,Feb 23 2007, 09:11 AM
This could be the solution - I had to do it: http://www.adobe.com/cfusion/knowledgebase...961&mode=simple
, and i also found what else was/is wrong. When you download the RAW plug-in at adobe.com, it's not compatible with any version before CS2. I didnt even realize that i had been using Photoshop CS. A friend of mine gave me CS2, but the data1 file was bad, and i never installed it and just kept using my CS. Now i wish i had fixed it
