Sigma Vs. Tamron
#41
You can't test a lens's sharpness in not ideal conditions. My Tamron outside in midday produces RAZOR sharp photos at 2.8. They are so sharp, that pixel peeping an eyelash is STILL sharp.
#42
Originally Posted by JoeyBalls,Oct 25 2010, 07:04 PM
usually lens' are at their sharpest stopped down to F8 or so, 1.4 is a very shallow DOF and things appear soft, but they are just out of focus..........
#44
^ Larger F stop (small F Number) is a larger opening, allows more light in, gives you a higher shutter speed in low-light (fast lens) Also has better Bokeh
this is a quick and dirty, i'll let someone else chime in
#45
have you guys used the nikkor 1.4G?
I blew up the picture in ps last night and checked out the pics i took @ f1.4 and color fringes are quite noticeable, i was a bit disappointed as I sold the 1.8D i had for this one..
I also noticed that even at f1.4, if you don't have a steady hand, you're not getting good shots with available lighting.. which was why I got the 1.4...
#46
so the lower the F stop the faster the lens can shoot in low light? I know my kit lens is real slow in low light. I didnt know that had to do with the lens i figured that was the body or something.
#47
#48
longer shutter speeds (lower fractions) and bigger lens opening (larger aperture, smaller f-number) let in more light.
a higher ISO is more sensitive to the light you have, at the expense of noise.
along with changing the amount of light, the changing aperture also adjusts the depth of field - (wider opening gives shallower depth of field - your subject will be in focus, but things in front and behind of will not).
shutter speed is how long the shutter is open. the longer it's open, the more movement (both of the subject and the shooter) has an effect. a tripod (or VR) can address shooter motion, but with moving subjects, your limited by shutter speed.
ISO is sort of the last step, ideally kept as low as possible that will provide for the necessary minimum shutter speed required, given the desired depth of field.
#49
Originally Posted by NFRs2000NYC,Oct 11 2010, 09:46 PM
As a whole, yes, Nikon/Canon is better than both. However, there ARE a small amount of lenses from the third party guys that IMHO are better optically than their Nikon/Canon counterparts.
