Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
DRL
Old Jun 12, 2006 | 03:09 PM
Psychoblur's Avatar
Originally Posted by koala,Jun 12 2006, 02:54 PM
Gary works at Yellowhead Honda.
The DRL's need to basically be the highbeams at half power.
Oh damn! So this is the Gary you guys are talking about. Haha. I'm too stupid to figure that out.
If its 50%, then that should be no problem. Probably will look better in the day than just high beams.
Thanks!
Old Jun 13, 2006 | 08:37 AM
VTR_Gary's Avatar
I'm going to have to look into the kits we have installed. As I recall, most of them run the low beams when the engine runs. Factory stuff runs the highs at half power but that would be more difficult to do, as it requires running the high beams in series. Certainly not impossible, but more time consuming to set up.
In 1990, the first year of DRL's in Canada, the low beams came on. This of course ended up using a bit more energy and running the low beams all the time shortened the time interval between bulb replacements. 1991 was when they switched to half power high beams. As you have HID's, bulb life should not be an issue, nor should power consumption. If it were my car I'd likely run low beams for DRL's. Legally, as long as something visible is lighting up in the front, you're covered for DRL's (there's probably a minimum wattage requirement which won't be an issue.)
I'll check on the price of the kit for you. I'll also look at the wiring diagram and try to figure out what I'd have to charge to run half power high beams instead...
Old Jun 13, 2006 | 03:11 PM
Psychoblur's Avatar
Great, thanks Gary!
daytontp
Apr 19, 2006 12:38 PM
jasonw
Feb 16, 2006 01:22 PM
mugenrsx
Dec 23, 2005 05:34 AM
x mj x s2000
Jul 17, 2005 04:58 PM
