Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
HID high beams
Old Jul 28, 2005 | 05:23 PM
koala's Avatar
Default HID high beams
Back when I had my '02 RSX-S I had HID's retrofitted. When I traded that car in for my first S2000, I sold the kit to a buddy of mine. He's now potentially trading in his car, so I might take the HID's off his hands.
My question is basically, am I crazy?
I'd have to find a place to mount the ballasts, first of all. Second of all, how badly do I need HID highbeams?
Please let me know how insane I am, thanks!
Old Jul 28, 2005 | 05:28 PM
xviper's Avatar
Two sets of HIDs inside the headlights might create too much heat.
Old Jul 28, 2005 | 07:25 PM
chrissa's Avatar
The high beams double as your daytime running lights. The S2000 sends a 6 volt signal to the high beams in DRL mode (the entire headlight/DRL circuit is controlled by a DRL black box). You'll have to rewire the lights to provide 12 volts to the ballasts. And depending on how simple or how complex you want to make it, you may have to do away completely with your DRL or have your DRLs running at full blast (I don't think there's any in between with HIDs). And if you do use them as DRLs, you have to have them turn off when the regular high beams turn on. There's a little work here.
But, I've read on this site about people who have retro fitted HIDs. I don't know what the details of the install were. Maybe a simple pair of relays that could be driven by 6 and 12 volts would do it. That would keep the DRL functionality. The only difference is the DRLs run at full blast. No different than driving around with your headlights on all the time.
Chris.
Old Jul 28, 2005 | 07:37 PM
koala's Avatar
Chris-- I have my DRL's disabled as of right now. I know they're a safety feature, but I like the clean look of the car without the DRL's on.
Dave-- Good thought about the heat. That does concern me a bit.
Old Jul 29, 2005 | 02:01 PM
kenny's Avatar
The addition of HID highbeams in terms of heat shouldn't be a big issue unless you use the high beams excessively. I've never measured the actual temperature that an HID bulb gives out but rough experiments with halogen bulb and hid bulb held near my hand show that the halogens put out more heat.
Old Jul 29, 2005 | 08:15 PM
Tommy_Gunns's Avatar
HID's run cooler than Halogens.
NDAZONE
Dec 2, 2005 07:09 PM
Wisconsin S2k
Apr 4, 2005 09:07 PM
GSU S2000
Oct 23, 2004 04:16 PM
dangarza
Jul 9, 2003 02:15 PM
