Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
My car got rust
Old Jun 29, 2005 | 06:40 PM
Seks's Avatar
Default My car got rust
So today was the first time I put the top down after god knows how long. After putting the top down, I walk around the car and guess what I see...?
I'm sure you guys can figure it out from the picture of where the rust is. It seems like a chunk of the foam got sliced out, exposing the metal to the elements???
I did a search on the forum board here but it doesn't seem like I could find someone who has a similar issue as me.
Don't supposed there's some kind of a TSB? The right side is fine though (foam still intact)
Old Jun 29, 2005 | 10:25 PM
LUV2REV's Avatar
You should still be under warranty. Have you shown this to your Honda dealer ?
Old Jun 30, 2005 | 06:57 AM
xviper's Avatar
If you're still under warranty, have them look at it. However, it may not be sufficient for them to actually do anything about it. Rust warranty is a funny thing. You almost have to have a complete rust through of a specific size before anything will be done.
Mine shows metal but the paint is in tact - no rust. It may just be surface, superficial rust. Can it be wiped off? If so, clean it off well with a non-metallic scrubbing pad, dry it, and put a bit of touch up paint on it.
Old Aug 11, 2005 | 04:08 PM
Seks's Avatar
[QUOTE=xviper,Jun 30 2005, 07:57 AM]
Old Aug 11, 2005 | 04:40 PM
xviper's Avatar
Originally Posted by Seks,Aug 11 2005, 05:08 PM
I can just use water with the pad?
Someone suggested using sand paper but i think that may be a bit too much
Try that and see how well it comes off. Sandpaper is only if it doesn't come off. It that's the case, you've got some work ahead of you. ...................................... Sand it down, clean it up, dry it off, primer it, paint it.
Old Aug 20, 2005 | 01:24 PM
CokerRat's Avatar
Consider using some rust remover from your local hardware store. It will dissolve the rust, leaving you with a relatively clean surface. A little sanding in trouble areas might still be your best insurance against the problem recurring. Paint and pray.
Old Aug 21, 2005 | 10:43 AM
Seks's Avatar
I used a 150 sandpaper, and sand down that little area. Then I use some anti-rust stuff on it. I didn't put any primer or anything on it. Should be OK?
andykim7
Jul 10, 2007 08:00 PM
J_J
Inland Empire S2000 Owners
Apr 14, 2007 10:08 AM
fluffyninja
Jul 2, 2006 11:48 AM
YeLLoWs2knVA
Jun 8, 2006 09:45 AM
IcebergS2000
Apr 2, 2006 07:42 AM
