Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
My car just about died tonight
Old Jun 8, 2003 | 10:35 PM
koala's Avatar
Default My car just about died tonight
So a buddy of mine and I decide to go for a drive in my car. Backing out of the driveway, I stall at the bottom (I have to go so slow so that I don't scrape, this is the first time I've stalled though). I'm like bah, guess I can't drive. So I go to start the car back up, it wont turn over. I'm like wow, this isn't cool. So I turn off the HID's, take the key out, wait a couple of seconds. Then I put the key back in, try to start it, still wont turn over.
Third time I put the gas pedal down a bit (I know this shouldn't even be done/neccessary on a fuel injected car)... car barely starts, sputters quite a bit, so I give it some gas to hold the revs at about 2,000... after 10 seconds, I let off the gas, let the car idle, it sounds fine...
basically, the point of all my rambling is I'm wondering what could have caused this?
-Water in the intake/engine (I do have a CAI, and I've always said I don't see how you could injest water, so maybe my theories are coming back to bite me in the ass?)
-Weather changes (ECU didn't like a 10 degree change in weather since the last time I drove the car ?)
Can't think of what else it could be!
Old Jun 9, 2003 | 09:51 AM
HondaGal's Avatar
Foot on the Clutch
Old Jun 9, 2003 | 02:48 PM
xviper's Avatar
When you say it "didn't turn over", this to me, means that when you hit the start button, NO CRANKING, NO NOISE, NO NOTHING! Is this what you meant or did it actually crank but did not start well? Because if it "does not crank", it will NOT even "barely" start - your engine does NOT turn over.
If it cranked, then did it crank at more or less the same speed as usual but just did not fire.
I'm trying to determine if you have an issue with the starter motor or an issue with the car's electronics or both.
Old Jun 9, 2003 | 03:54 PM
FormerH22a4's Avatar
Hmm, there hasn't been heavy rain for a while so don't think the CAI was causing it. Xviper's questions will tell us more about that condition.
Old Jun 10, 2003 | 07:06 AM
koala's Avatar
Sorry, I should have said "it was trying to start, but simply wouldn't go past the 'cranking' point"
I'm not good at describing these things
Anyhow, I'm not too worried, car is fine... I guess I just found it odd.
Old Jun 10, 2003 | 08:31 AM
xviper's Avatar
I'm guessing it was a momentary "ignition" problem or "fuel" problem.
I would suggest that since you did not get a CEL, you should just go ahead and do a quick ECU reset. Won't hurt. Also, give the old MAP sensor the "whack job".
Tjs S2k
Nov 15, 2008 07:29 AM
jimmied
Mar 14, 2005 07:13 AM
s2kboy03
Nov 22, 2004 09:51 PM
sickestS2k00
May 18, 2004 12:32 PM
baldy74
Aug 31, 2002 10:29 PM
