oil level
Dino oil = "normal" oil. As opposed to "synthetic" oil. You said you are just below the "add" mark. It takes 1L to go from the "add" mark to the "full" mark. You'll need at least 1L to bring it to full. You should keep another one on hand to top up as you use the oil up over the next bunch of KMs.
ok... i just bought a 1 liter of 10w30 at petro just to fill it up real quick...
my oil is still pretty low... its under the "L" i guess right before i filled it , it was rpetty much nothing! so i have to go buy some more tomorow! i cant beleive how low it was!!! good thing i was searchin around s2ki and was reading up on the maitenance
oh when i first checked it there was oil but it looks more like splatter marks rather then a readable level.... so i will run my car then when i get to work i will check the oil, but the oil level has definitly gone up... i guess every gas fill im going to be checking on the oil
If you must check it HOT, then get used to pulling the stick out immediately upon shutting the engine off (wipe the stick clean), leave it out for 3 - 4 minutes to allow the oil to fall out of the dipstick hole, then put the stick back in and take your reading. This will minimize or eliminate the "splatters" that you noted the other time you checked.
ok finally my oil is up to the top!!!!
do not get gas station oil... it was sooo think.... it took quite a long time to finally go down the funnel.... then i got quaker state when down like water in the funnel.... huge difference!!!!
i learned my lesson... i will be checking my oil on a weekly occurance!
10W30 dino oil should all be the same viscosity. Maybe one was kept outside? I never buy my oil at a gas station. They hose you on the price. Walmart or Crappy Tire. If by chance the Quaker State was also outside and it poured thin, this should tell you something about it's quality.
