Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Running Documentary on my 1st - 2nd grind...
Old Jun 7, 2003 | 08:30 AM
FormerH22a4's Avatar
Update: I recently changed the clutch fluid, which was really crappy. It was really black, with floaty things as xviper calls them. Initial impressions is that the 1st-2nd shift is now back to normal where it was last summer. The clutch engagement point is a bit higher now and I can feel the synchros engaging at the 2nd gate. It is early but seems like this was the cause of the grinds that started beginning of March.
For the guys who drive over winter, go out and check your clutch fluid since Vlad's was black as well and he has had the car the same time as myself.
Old Jun 11, 2003 | 10:45 PM
Update: One problem gone, another still remains. I've always had an issue with 1st gear being sticky to get out of. The issue goes away when the tranny heats up. I am thinking my car has clutch engagement problems so we'll see what the dealer can do, i am still taking it in to chase down the final and only issue I have left with the car.
Old Jun 12, 2003 | 10:56 PM
HeLLSpiRE's Avatar
you forgot those rattles those issues will never go away, but glad to hear that your car is back to normal. My car's been rather sluggish lately, dunno y tho...
Old Jun 13, 2003 | 06:24 AM
xviper's Avatar
Our increasing ambient temps may be the problem (if you can call it a problem). Might be time to incorporate some sort of cold air intake.
Old Jun 13, 2003 | 07:42 PM
The grind is BACK!
I drove around the city tonight after hitting a few at the driving range since it was so nice. I took a half lap of Calgary and near home, grrrrrrrrr.....
it was in high rpms too, about 7500rpm. This is the first time in the high rpm range.
The clutch fluid change helped but I think the clutch is still dragging somehow.
To make things worse I was right beside running with a Celica GTS, now they probably think S2ks are crap. Sorry for tarnishing the name guys.
There goes my vacation, my S will probably go under the knife in a week or so if I can re-create again
Old Jun 16, 2003 | 10:32 PM
max_boost's Avatar
I experienced my first 1st to 2nd gear grind today. Let's just say that I am not too impressed by it! I just hope its driver error!!!!
Old Jun 16, 2003 | 10:36 PM
was it in high rpm or low rpm? Was it in traffic when the tranny was hot?
Old Jun 17, 2003 | 12:44 PM
max_boost's Avatar
I just passed VTEC in first gear around 8000RPMS when I shifted and was like WHAT THE FCUK WAS THAT?!?!
Old Jun 17, 2003 | 01:54 PM
xviper's Avatar
This could be anything from a true gear box issue starting to develop to old clutch fluid, a clutch pedal in need of adjustment, old tranny fluid or driver error.
Driver error can include poor synchronization of clutch, throttle and shifter or it could be inadequate left pressure on the stick as you pull down to 2nd.
Old Jun 20, 2003 | 05:46 PM
JetBlackS2000's Avatar
just did a 1-2 grind a block away from home after a trip to Invermere and back...medium range revs on shift
my reaction was wtf
that makes total of 3 grinds now
