Adhesive on paint?
I just bought a used 2007 S2000 and just below the left side marker (just in front of the driver's door) is what looks like adhesive. It *looks* like someone glued the side marker back on the car and got sloppy with the adhesive.
Any idea how I could get this off without damaging the car's finish? I can post pictures later if that would help.
Most likely what has happened, is.....Someone removed the side-marker, and broke the "Tab" off, that holds it in....Very common, and very easy to do !!!! Then they tried to glue the marker back on, because they apparently had a clear, or smoked marker on it, during their ownership....anyway, back on subject...Just use WD-40, to remove the adhesive. It will not hurt the paint. Then clean with alcohol, and wax as usual......You may want to check the marker light...If the tab is broken-off...It will surely fall out, sooner or later....Scroll down to clear side marker lights....
http://www.handa-accessories.com/s2000-04ext.html
Well the good news is that WD40 didn't damage the finish. The bad news is that it did very little to help remove the adhesive. I think it improved it somewhat, but it's still very noticeable.
if you're talking about 3m double sided tape , you can use a kind of eraser that you put on the drill
Work very well !
if it's only a type of glue , go buy a solvent done for this kind of glue
Work very well !if it's only a type of glue , go buy a solvent done for this kind of glue
